BX24 Turtle/Rabbit Setting When Backhoeing
   / BX24 Turtle/Rabbit Setting When Backhoeing #1
dhglaser
Should the speed range lever for the transmission be set to neutral when back hoeing.
I find that the tractor is difficult to move immediately after back hoeing if I leave the speed range level in low. Once I get the tractor moving (put the throttle at 2500 rpm) the tractor runs just fine.
Is this a problem then others have seen?
-David
   / BX24 Turtle/Rabbit Setting When Backhoeing #2
What's the manual say?
   / BX24 Turtle/Rabbit Setting When Backhoeing #3
Do you mean difficult to shift into low range from neutral? I've been leaving mine in low range while using the backhoe, (FEL down/ P brake on) no problems getting it to go afterwards. If the problem is shifting, the manual says to lightly tap the fwd or reverse pedal, and then shift. I've had to do this several times.
   / BX24 Turtle/Rabbit Setting When Backhoeing #4
You wouldn't happen to be leaving the parking brake on...would you? /forums/images/graemlins/smile.gif
   / BX24 Turtle/Rabbit Setting When Backhoeing #5
I would be smartest to keep the tractor in N while using the BH. Otherwise, you might have unintended tractor motion.
   / BX24 Turtle/Rabbit Setting When Backhoeing #6
I put mine in "N" while using the BH. Havent had any problems yet /forums/images/graemlins/grin.gif
dj
   / BX24 Turtle/Rabbit Setting When Backhoeing #7
Some folks like to put it in "N" so they can adjust tractor position with the hoe.
In most cases I leave it in low so I can turn around and move the tractor slightly forward or back with my hand on the pedal. Safety police may frown on that, but in many instances it works well.
   / BX24 Turtle/Rabbit Setting When Backhoeing #8
Me too. I found that I can lean back, and move tha tractor with my hand on the peddle easier than moving it with the hoe. Plus if you pick up everything (loader, outriggers) it won't roll with you facing backwards away from the steering and brake. That was a fun half second that seemed like an hour untill I remebered to dig the hoe in.
   / BX24 Turtle/Rabbit Setting When Backhoeing #9
I leave it in gear also so I can move a few feet without moving seat. Never had a problem, I leave the loader on the ground and have the stabalizers down to keep me in place.
   / BX24 Turtle/Rabbit Setting When Backhoeing #10
My 23 i leave in gear for the reach around and move trick.The tires on front and back should be off the ground when digging any way.
ALAN
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
