BX24 Battery
/ BX24 Battery #21
Whatever....
On my BX23 I just go to Wally World and look up the battery for a Dodge Neon. It's the right size and terminal orientation. Usually about $80 out the door. 10 year life is not typical (at least here in Texas).
/ BX24 Battery #24
Make sure the terminals are correct. The BX uses a REVERSED terminal battery. The + pos and - neg are reversed. So the number should end with an R.
/ BX24 Battery #25
I just replaced my original Deka (9 1/2 years old) with a 26R from Napa. I asked them for the one with the highest CCA. Side by side the NAPA one looked identical to the original Deka. I looked up the specs and they are the same. My guess is it is the same battery. It fit like a glove.
/ BX24 Battery #26
I have replaced the battery twice on my BX24. The first time I used a Dodge Neon battery from Costco. The problem was it had to be jammed into the compartment with no room to spare. This means I couldn't add Battery Tender connections or a 30 amp feed for my tree sprayer. The correct battery for the BX series is a Group 27R. Lots of power and room to make connections.
/ BX24 Battery #28
I believe you mean a size 26R. A size 27 battery will never fit in the BX. A 27 is one of the bigger batteries made and they don't make a 27R, for some reason it's called a 27F.
I just put a size 26R Interstate battery that I bought from Northern Tool and it fits perfectly.
Group L" W" H"
26R 8.20 6.90 7.80
27 12.10 6.80 8.90
27F 12.10 6.80 8.90
Ref: BatteryWeb, Inc. - BCI Group Numbers, Dimensional Specifications, Polarity and Terminals
/ BX24 Battery #29
Group L" W" H"
26R 8.20 6.90 7.80
27 12.10 6.80 8.90
27F 12.10 6.80 8.90
You are correct. I was relying on my memory. 26R is the battery. I bought it from O'Reilly's for about $90. Sorry about that.
Here is the original reference I used:
http://www.carquestprofessionals.com/batteries/BatteryApplicationGuide.pdf.
Page 124 has the Kubota.
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
FORD DIRT SCOOP (A62131)
FORD DIRT SCOOP...
2015 International WorkStar 7500 T/A Dump Truck (A61568)
2015 International...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
2011 Bobcat E50M Mini Excavator (A61567)
2011 Bobcat E50M...
2014 BMW 550i AWD Sedan (A61569)
2014 BMW 550i AWD...
