BX23 water pump questions
   / BX23 water pump questions #1
tshep
Richmond, VA
BX23 MLB
So, situation is BX/54 mower runs right up at orange with tall grass.
Recent work shows clear radiator (in and out), minimal internal rust, etc.
I believe I would NOT trust the water pump next.
I got tractor only a few years old.
Is it likely the original pump was a cast or formed (SS?) impeller?
Long term - should I seek OE or other water pump, formed or cast?
   / BX23 water pump questions #2
I owned a BX2350 for about 10 years. They tend to run hot. Mine would get up near the red if cutting really tall grass. Before I even got the tractor home they told me that was the case. If just cutting my lawn it would get close to the red but not in it.
  • Good Post
Reactions: JWR
   / BX23 water pump questions #3
If you drop down a gear in the tall grass will the tractor still get hot? I don't like to run my tractor hot; not enough margin for error.
   / BX23 water pump questions #4
Take the thermostat to Napa, they can probably match it up with another by size that is rated for lower temps, or just replace it with a new OE one to see if that fixes it. Water pump could also be an issue, but thermostats tend to be a lot cheaper and easier.
   / BX23 water pump questions #5
Agree with Dodge Man. They do run on the hot side. I've owned 4 Kubotas and maintained 2 more. Every one of the BX ran almost to the red cutting heavy grass in hot weather. That said, I have run across several factors over the years: 1) Keeping the screen blown clear in front of the radiator is essential. They are very sensitive to that. 2) I could find absolutely NOTHING wrong with one that was running hot and even though the radiator "seemed" Ok replacing the radiator cured the issue. 3) One of them had a nick in the seat of the thermostat and brand new thermostats had no effect. Overflowing frequently of course. Finally found the nick and reamed it smooth to fix the issue. 4) The most elusive overheating issue among the several BX I've worked on was on a BX2200 that just would not "get OK" no matter what we did. After I sold it, the new owner (Mennonite mechanic) discovered the lower radiator hose was collapsing and lacked the normal spring inside to prevent that. He put in a spring and fixed that one too.
I have long believed that the BX 3 cylinder engines have too small a capacity water pump. I say that leaves it vulnerable to a long list of things that it should not be vulnerable to. Have not gone far enough to see if a water pump from a slightly larger 3 cyl diesel Kubota engine might have higher output and might fit.
I'm still beating on it.
Pump looked great inside, went back on.
Radiator at shop, guy said his chemicals pretty good.
I'm real suspicious now of that un-sprung lower hose.
   / BX23 water pump questions #7
I'd sure check that hose, or better yet just replace it with one having the internal spring.
The other place that can cause overheating is where the fan shroud attaches to the radiator.
Sometimes there is an air gap there which allows the fan to draw air in from the sides of the shroud instead of being pulled in through the radiator fins. The cure is to seal the gap with automotive weatherstripping.
luck,
rScotty
   / BX23 water pump questions #8
My BX2200 can get hot if I'm doing heavy (mostly during the spring) mowing with the MMM. It's the only implement I see this happen on.
A few years ago now, I mowed a little over 5 acres of 2-4' tall grasses with a 62" flail mower and it was running fine. Just a tick above the middle mark.
Otherwise, the needle stays right in the middle doing anything else after it's fully warmed up.
I know it's not anything with the MMM (bearings/gearbox) because I've been though it like a fine tooth comb. Very fluent about these Kubota MMM decks.
I need to try a 60" or 72" RFM and see if it produces the same results.
The only thing I don't like about the BX series machines is the reverse engine layout.
   / BX23 water pump questions #9
I had a BX24 when it ran Hot I would need to tighten the fan belt. About every two years I would need to replace it as it was worn out. After replacing it would run in range as long as I kept the belt tight. The first time I replaced it it was a Learning Experience as the belt was driven by the drive shaft. The third time I changed it I was a Pro.
   / BX23 water pump questions #10
My BX2660 will get hot if I don't keep the radiator clean. Even with the screen in place dirt still clogs the radiator so I need to wash it out a couple of times a year.
   / BX23 water pump questions #11
I've had an experience with a waterpump that I replaced and the impeller was plastic and the pump casing was metal. Under load the impeller slipped on the spline. At normal running loads it didn't slip and the temperatures were normal. I would never buy a water pump with a plastic impeller again.
  • Good Post
Reactions: JWR
Well, it's back together. Shop made a pretty radiator out of mine! Stat opens fine, 20 + temperature drop across radiator.
Cannot really see water flowing through tiny cap port, but w/ and w/o stat temp drops.
Mower running (no grass) traveling was straight up.
Gonna' have to test it on the field, observe for hose collapse (couldn't find spring that thin). They did create quite a U shape (extra 90s) that looks like it would love to fold up.
THX guys.
   / BX23 water pump questions #13
HOT day and tall grass means poor cooling conditions. Happens to me with my B7800 and I adjust by slowing down; I'll also take note of wind direction and try to mow into the wind. (and if you run with a bucket, as I do, raise it out of the way of the radiator grill area)
   / BX23 water pump questions #14
It’s a Kubota. They make some of the best small diesel engines on the planet and then habitually put them into their equipment with a marginal cooling system. My fix was having a radiator made with approximately 3 times the capacity and coarse fins to keep it from plugging.
   / BX23 water pump questions #15
...and if you are that close to lacking adequate cooling there is something serious wrong !
Boat (A59231)
Boat (A59231)
2022 CATERPILLAR PM622 COLD PLANER (A60429)
2022 CATERPILLAR...
207274 (A52708)
207274 (A52708)
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
FORKLIFT (A56857)
FORKLIFT (A56857)
2022 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A60429)
2022 BOMAG...
