bx23 front axle bolt
/ bx23 front axle bolt #1
tk tom
hollis, me
B2650, GX335
I'm looking for the front axle pivot bolt nut torque spec, can't seem to find it and don't have a manual. The tractor has 796 hours on it and there's an intermittent/inconsistent clunk coming from the front end, and I figure it's coming from there. It's doesn't seem to be related to 2wd/4wd or left or right turns, just different stress situations. Hopefully it's just a matter of setting the torque properly again. Thanks!
/ bx23 front axle bolt #2
I have a BX1500, (2005) and at my last service (400 hours) The service mech replaced the mounting bolt. It showed wear to the point that it was ready to fail. As the previous owner did almost now maintenance on my tractor (I had to totally rebuild the mower deck), I was not surprised.
/ bx23 front axle bolt #3
I also have a bx1500. My manual says to tighten the adjusting nut to 15 lbs ft. If additional adjustment is needed to align the split pin with the hole tighten the nut to align. Manual says to check every 400 hrs. I really don't think that would cause a "clunk" though. Sounds more like something in the front axle gears. Have you checked the fluid level in the fron axle?
/ bx23 front axle bolt #4
I had a clunk that sounded like it was coming from the rear. Found the front axle adjusting bolt loose. Tightened it to the recommended torque and problem went away.
I haven't checked any fluid yet. The old man says he's on top of maintenance so I let him be. I buy him filters and fluids and such for letting me borrow it from time to time.
The noise definitely sounds like it's coming from the front, not the back. I'll get it torqued properly and see what happens. Hopefully the bolt isn't worn out. I don't know how long the clunk has been there.
Thank you for posting the torque spec, I'm sure it's not any different across models. I'll check the torque and see what happens.
2023 Bobcat T770 (A64126)
2023 Bobcat T770...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Farm Hand Silage Wagon (A65640)
Farm Hand Silage...
2011 Ford E-350 Passenger Van (A64556)
2011 Ford E-350...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
