B7800 front axle leaking
/ B7800 front axle leaking #1
twodogs
Pittsburgh, PA
Kubota B7800
I have a B7800 that has been leaking hydraulic fluid from the front axle. I had it in to the dealer a few times, and it is still leaking.
The first visit was a seal replacement, and it leaked within a day or two or getting it home.
They took it back and put a 'speedy sleeve's in, and it leaked again. They also overfilled it with fluid, so I drained some, and put it away for the winter.
It started leaking again, but health issues put me out of commission for several minutes months, and now I am dealing with it again. The dealer now tells me that I need a new front axle case, brackets, seals, etc. for the total of about $2500...
I am a homeowner with a small farm. It has about 1600 hours on it, most of which is cutting grass or running a brush hog.
Does this seem premature? I bought this new 18 years ago, and it has been well cared for throughout it's life. Fluids have been changed religiously, and it has been garage/barn kept. I'm a bit perplexed - maybe I had unreasonable expectations when I bought it.
Thanks for your insight.
/ B7800 front axle leaking #2
just curious if you are running the UDT oil in the axle or gear oil, if UDT I would try the heavier gear oil. Gear Oil is what I run in my b7800
I have run the Kubota Super UDT in my tractor.
/ B7800 front axle leaking #4
What I am hearing is 18 years, 1600 hours, and you are using the proper light oil in the front axle. IIf you have a FEL on it. I'm not surprised that it is time for outer seals and maybe bearings on the output side of the stub axles. Those parts get a lot of stress on small 4wd tractors.
I'd say It is not what we like, but it is not uncommon for some slight seepage at the ends of the axle even on tractors with less hours than yours. All the small to medium 4wd tractors are using that same front axle now that the original patent expired back around 1980. They are all very similar. The first thing to do is make sure that the axle vent is clear, that the oil level is right, and yes, it is common to go to a heavier - higher viscosity- gear lube once the seals start to seep. But heavier oil is a stopgap measure.
In my opinion as an old mechanic, those outer seals and bearings are pretty much routine maintenance. It isn't an expensive or difficult job. What you are saying makes me wonder about the shop doing the work. It is a simple job, but it is a job that needs a lot of careful assembly.
I'd chalk it up to experience, find yourself an old experienced mechanic, let him fix it... and it will be good for another few thousand hours.
rScotty
/ B7800 front axle leaking #5
If it were mine, I would switch to gear oil and make sure the vent is open.
If that didn't solve the leak, decide what to do from there.
Thanks! The dealership service manager admitted that the tech that worked on it last sucked, so it makes me wonder if they did more harm than good there.
I appreciate the advice.
/ B7800 front axle leaking #8
My Ford 1310 used to have oil seal leak in the front axle, here is how I dealt with it (easy fix and it did not cost much):
Venting Leaky Ford 1310 Front Axle & switching to 85W-90 Gear Oil
As of yesterday no leaks 3.5 years later!
The reason that old mechanics keep harping on the vent is that some of those very similar front axles came vented and some did not. Regardless, they all need to be vented. If the front axle housing is not obviously vented, you can vent it by replacing the oil fill bolt with a vented version.
When the original bevel gear front axle came out in the mid 80's the manufacturer's reccomended oil was not consistenat. It varied from light weight to higher viscosity gear lube. Over the years, many mechanics started with the light weight and moved toward higher viscosity if&when the front axle seals started to seep.
rScotty
/ B7800 front axle leaking #9
/ B7800 front axle leaking #10
the factory vent on the B7800HSD
6C040-36070 PIPE, BREATHER​
The B7800 is vented. Is there a realistic chance that it is not functioning? I have not driven through anything that would have clogged it. The only issue I could think of is insects...
/ B7800 front axle leaking #12
Around here you see a lot vents clogged by those mud-dauber wasps. Sometimes a clear piece of hose on the vent seems to keep them away. Our littlest tractor had the 3p & rear axle housing vented behind the seat and that vent was like a magnet for mud daubers. I finally put a copper pipe on the vent and eventually a piece of clear hose with screen in the hose.
Hard to tell if venting was your problem originally, but it makes sense to check it. After the work you say you had done I wouldn't bet on anything.
I was thinking about what you wrote where your dealer says he hired a poor mechanic and guy maybe messed up your front axle... In my opinion that becomes an obligation on the dealer to help fix the situation. Maybe give him a chance to make it right.
rScotty
I went to the dealer today and saw the axle. These are a few pictures.
/ B7800 front axle leaking #14
Didn’t see any mention of where the front axle is leaking FROM …
Given your pics above, is it from the axle center pivots ? (Rather than from the bevel gear case pivots on each wheel)
If so I can tell you there is a replaceable bushing in at least the front pivot.
I replaced that bushing in my B2910 @ around 2500 hours.
Thanks! The picture of the axle itself shows the scoring. I was told that this is why a speedi-sleeve would not work when attempted previously.
/ B7800 front axle leaking #16
There is very limited movement in the front axle - yes the scoring is there, and could this be sanded smooth then insert some shims to tighen it up?
Here's the diagram and parts list - appears the housing at $735 is the expensive part - that's why maybe a machine shop and some bushings would be a less costly approach.
/ B7800 front axle leaking #17
And that's why you dont forget to grease every fitting..even if it's hard to get to.
/ B7800 front axle leaking #18
So the top of the bushing is where the wear occurs and I suspect the oil level is half way up the bushing requiring the oil to literally splash into the wear area when the tractor is running. Poor design I would think. Thin lubricant (hydraulic oil being anywhere from 10 to 30 weight) has poor ability to "hang" on a surface.
If you run on primarily level ground, I would assume no oil gets to the actual wear point.
I would agree with Carl_NH above, I would throw all three parts (front hanger as well) in my truck and head to a reputable machine shop for hopefully a cure.
/ B7800 front axle leaking #19
Every Kubota that I've owned (have had at least 10 over my lifetime) has grease fittings on the lower and upper part of the pivot casting and they need to be greased regularly. I grease mine until I see grease coming from the joint. Easy to miss but they are there. One on the bottom side and one on either the right or left side about halfway up by the front prop shaft.
I don't believe there are any grease fittings anywhere near this wear point.
