BX23 D905 Block Drain
   / BX23 D905 Block Drain #1
tshep
Richmond, VA
BX23 MLB
I wasted a lot of time looking at other BX's - so for archiving:
On a BX23 with D905:
Block drain is RIGHT side, towards radiator, under 905 casting mark, 2 'plugs' in vertical line, upper one internal hex (looks like pipe plug) lower one hex head BLOCK DRAIN with copper washer.
As we have learned, pics longevity is not reliable....
   / BX23 D905 Block Drain #2
(Snip)
Not sure what this means…unless something changed recently.
I have viewed pictures in threads over 15 years old fairly recently. Granted you have to click on the link to the image in each post…
I think of these as long term tractors, and here as long term archives.
I was referring to when photo bucket, was it, virtually killed a generation of web photos web-wide.
   / BX23 D905 Block Drain #4
Got it!
Forgot to thank you for posting that specific info on the drain plug location! (y)
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
Air Pressure Gauges/ Controllers (A56860)
Air Pressure...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 Freightliner Coronado (A60460)
2015 Freightliner...
