Bx23 60'' MMM belt.
   / Bx23 60'' MMM belt. #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Bx23 60\'\' MMM belt.
Found a piece of slag about the size of a pencil eraser embedded in the belt.
It cut about half way through from the outside in.
Wonder what effect if any that will have on the life of the belt?
   / Bx23 60'' MMM belt. #2
Re: Bx23 60\'\' MMM belt.
No experience with the Kubota belt but the Gates tooth belts on a Harley can be holed by a pebble if it gets between the belt and the pulley. This is not a cause for concern if the hole is towards the middle of the belt.
</font><font color="blue" class="small">( No experience with the Kubota belt but the Gates tooth belts on a Harley can be holed by a pebble if it gets between the belt and the pulley. This is not a cause for concern if the hole is towards the middle of the belt. )</font>
This goes from the top of the belt through about half of the thickness of the belt and is right in the center of the width of the belt.
   / Bx23 60'' MMM belt. #4
It doesn't sound like it damaged the cords. Pick the slag out, if it's not already out, and run it. Should be OK.
</font><font color="blue" class="small">( It doesn't sound like it damaged the cords. Pick the slag out, if it's not already out, and run it. Should be OK. )</font>
That's what I did.
Mowed the yard - Worked fine.
I learned on thing though don't run the mower with stuff on top of the deck - clean it off before using.
Could save you a $100 belt.
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Ford F-250 Ext. Cab and Chassis Truck (A50323)
2013 Ford F-250...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
