Bx23 60'' MMM belt.
   / Bx23 60'' MMM belt. #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Bx23 60\'\' MMM belt.
Found a piece of slag about the size of a pencil eraser embedded in the belt.
It cut about half way through from the outside in.
Wonder what effect if any that will have on the life of the belt?
   / Bx23 60'' MMM belt. #2
Re: Bx23 60\'\' MMM belt.
No experience with the Kubota belt but the Gates tooth belts on a Harley can be holed by a pebble if it gets between the belt and the pulley. This is not a cause for concern if the hole is towards the middle of the belt.
</font><font color="blue" class="small">( No experience with the Kubota belt but the Gates tooth belts on a Harley can be holed by a pebble if it gets between the belt and the pulley. This is not a cause for concern if the hole is towards the middle of the belt. )</font>
This goes from the top of the belt through about half of the thickness of the belt and is right in the center of the width of the belt.
   / Bx23 60'' MMM belt. #4
It doesn't sound like it damaged the cords. Pick the slag out, if it's not already out, and run it. Should be OK.
</font><font color="blue" class="small">( It doesn't sound like it damaged the cords. Pick the slag out, if it's not already out, and run it. Should be OK. )</font>
That's what I did.
Mowed the yard - Worked fine.
I learned on thing though don't run the mower with stuff on top of the deck - clean it off before using.
Could save you a $100 belt.
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Kioti LK2554 Tractor (AS IS) (A50774)
Kioti LK2554...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
