Bx23 60'' MMM belt.
   / Bx23 60'' MMM belt. #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Bx23 60\'\' MMM belt.
Found a piece of slag about the size of a pencil eraser embedded in the belt.
It cut about half way through from the outside in.
Wonder what effect if any that will have on the life of the belt?
   / Bx23 60'' MMM belt. #2
Re: Bx23 60\'\' MMM belt.
No experience with the Kubota belt but the Gates tooth belts on a Harley can be holed by a pebble if it gets between the belt and the pulley. This is not a cause for concern if the hole is towards the middle of the belt.
</font><font color="blue" class="small">( No experience with the Kubota belt but the Gates tooth belts on a Harley can be holed by a pebble if it gets between the belt and the pulley. This is not a cause for concern if the hole is towards the middle of the belt. )</font>
This goes from the top of the belt through about half of the thickness of the belt and is right in the center of the width of the belt.
   / Bx23 60'' MMM belt. #4
It doesn't sound like it damaged the cords. Pick the slag out, if it's not already out, and run it. Should be OK.
</font><font color="blue" class="small">( It doesn't sound like it damaged the cords. Pick the slag out, if it's not already out, and run it. Should be OK. )</font>
That's what I did.
Mowed the yard - Worked fine.
I learned on thing though don't run the mower with stuff on top of the deck - clean it off before using.
Could save you a $100 belt.
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2009 Ford E-350 Cargo Van (A50323)
2009 Ford E-350...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
