BX2230 LED Lights (4) installed and working BUT....
   / BX2230 LED Lights (4) installed and working BUT....
Looking at yout switch... You have 3 terminals. I suspect that the bottom two is for the red side of your wire. You need to physically cut wire and crimp on a push on blade type connector on both sides of wire. The third terminal that is for allowing the led to lighy up i suspect and you need a wire from that terminal and use the plastic connector you have shown to the ground wire that goes back to black side of wire . if i remember correctly the wire bullet connectors on tractor wasnt color coded i think... You need to use the meter to confirm the positive. And negative side. Just be sure positive goes to switch on bottom terminals ans side terminals uses the pish connect on wire going back to negative side. Mind you.. Do all the cutting and splicing on the wire you ran side only. Never on tractor original wiring
Wow at 62, the brain cramps are every day now. Used the toggle pictured, with an in-line fuse, wired into the tractor's rear red harness wire and lights red (hot) wire. Just need to permanently mount it. Thanks for all the help and suggestions!
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
John Deere 853 20ft Corn Head (A56438)
John Deere 853...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
2006 Case 445 Skidsteer (A59814)
2006 Case 445...
