BX2200 won't start
/ BX2200 won't start #1
Ol Pops
Arkansas
Kubota BX2200
My tractor started fine this morning, and ran great for 30 min until I turned it off and went to restart it 20 min later.
Nothing happens when I turn the key, except the normal panel lights operate. The headlights work fine, I went ahead and charged the battery.
I'm thinking I should start by checking the starter and the key switch, but I'm not sure how to check these out. Also, is there a relay I should check out?
Appreciate your input,
Thanks, Pops
/ BX2200 won't start #2
I am not a Kubota owner, but here are some items you can check. I would start with checking the HST pedals are neutral position/centered
Check fuses
Safety switches (seat, PTO, neutral switch)
Make sure in Park/Neutral HST pedals in neutral position/centered
Make sure you have power at the starter/solenoid
Make sure starter and solenoid working
Check battery under load
Check all starter connections (including grounds) for corrosion and tightness
/ BX2200 won't start #3
Its almost always a saftey switch. Jiggle the PTO lever first, than the HST pedal, and bounch up and down in the seat a little while your at it.
Thanks!!
You nailed the problem!
I just checked everything and somehow I had bumped the pto lever and the safety had me shut down.
All's well again!
I appreciate your time and input!
/ BX2200 won't start #5
Your welcome, its happened to me more than once. I think I bump it when I get off.
