bx2200 quick hitch
/ bx2200 quick hitch #1
David Ripp
Seattle, WA
bx2200
I just purchased a bx2200 with the front end quick hitch. The snowblower attachment (2750) is on it. I would like to attach the rotary broom. What is the procedure to disconnect/reconnect. Need to know specific details to disconnect mid PTO. Thanks.
/ bx2200 quick hitch #2
Hi David, :welcome: to TBN.
I don't have a blower. But for the mower, reach in to the back of the shaft. There is a collar that you must slide toward the front of the tractor about 1/2 inch and then there is a detent there that should lock in place. Once you do that, you should be able to wiggle the shaft and work it forward and off the splines. I have got to believe that the blower uses the same type of shaft and collar as the mower, but I've been wrong before.
What are you doing with the blower? Oh, man. You're way out in Seattle. :( :laughing:
I'll give it a try, thanks! . The tractor is for our Cabin up at Snoqualmie Pass.
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2023 Kubota RTVX1120 (A60463)
2023 Kubota...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
Hay Spear (A60463)
Hay Spear (A60463)
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
