BX2200 DECK
   / BX2200 DECK #1
jagee
BX2200
I have a bx2200 with a rck60 deck, no matter where i put the adjuster knob the deck doesn't change height, i know its not a stripped knob because it is gone, i use vise grips. i adjust it with the deck raised. i bought it used and I did not ask the right questions. Its possible i bought it broken. it is all mine now whatever the issue. any suggestions besides you screwed up?
   / BX2200 DECK #2
Try loosing the drop rate knob below the seat. That can cause that since it controls the 3 point and the MMM drop speed
I guess I should ask does it drop at all and does the 3 pt drop all the way.
   / BX2200 DECK
i cant get the drop rate knob to move at all, the 3 point works fine, all the way up and down
   / BX2200 DECK #4
Yeah the drop rate valve likes to freeze up but if you 3 point drops so should the deck. The linkage is connected to the 3 point and just gravity down. The drop height is controlled by a stepped cylinder attached to the adjusting shaft. I can send you the service and parts books, too big to post here and I no longer have a server on line. Check your PMs
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2014 Timpte Hopper Bottom (A56438)
2014 Timpte Hopper...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2016 FORD TRANSIT 350 CARGO VAN (A59575)
2016 FORD TRANSIT...
