BX2200 DECK
/ BX2200 DECK #1
jagee
BX2200
I have a bx2200 with a rck60 deck, no matter where i put the adjuster knob the deck doesn't change height, i know its not a stripped knob because it is gone, i use vise grips. i adjust it with the deck raised. i bought it used and I did not ask the right questions. Its possible i bought it broken. it is all mine now whatever the issue. any suggestions besides you screwed up?
Thanks
/ BX2200 DECK #2
Try loosing the drop rate knob below the seat. That can cause that since it controls the 3 point and the MMM drop speed
I guess I should ask does it drop at all and does the 3 pt drop all the way.
/ BX2200 DECK
i cant get the drop rate knob to move at all, the 3 point works fine, all the way up and down
/ BX2200 DECK #4
Yeah the drop rate valve likes to freeze up but if you 3 point drops so should the deck. The linkage is connected to the 3 point and just gravity down. The drop height is controlled by a stepped cylinder attached to the adjusting shaft. I can send you the service and parts books, too big to post here and I no longer have a server on line. Check your PMs
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2011 Ford Expedition SUV (A64557)
2011 Ford...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
