Grading BX2200 3pt grader blade
   / BX2200 3pt grader blade #1
edney
Just picked up a 3 point 5 foot blade. Problem is I can't turn the blade around with out removing because it hits the lift arms. BX lift arms come from such a low pivot point that with any implment they are angled up even when implment is on the ground. Dealer where I got teh blade(not Kubota) says they typically want the lift arms to be in the same plane as he implement frame which is easy to do on a full size tractor but not so on compact. The easy solution would be a 5 foot blade that was only 12 inches tall instead of 14 then it would clear. I know a 4 footer would make it but wanted the extra width so that when angled it still is wider than tractor. Kubota blade is 4 ft. Anyone know a brand of blade that is purposly sized for subcompact tractors?
   / BX2200 3pt grader blade #2
I have the Woods Estate Series back blade - made especially for sub compact tractors. I use it (and the Woods estate series landscape rake) on my bx2200. Both work great; no problem reversing them; and, with the blade in reverse, I can lift it 16 inches off the ground. I wanted that so I could "reach over" snow. I may drill holes in my lift arms and the arm lifters to get even more height. (Haven't got around to putting snow birds on my metal roof yet!)
   / BX2200 3pt grader blade #3
I have a woods RB5. Works great. Lifts real high. In fact I used the hitch points as a pattern for my box blade to get the pins lower and narrower to work with my 2200. The Box blade has now become a very useful tool. Could only raise it about 4 inches before.
Tom
   / BX2200 3pt grader blade #4
Where did you guys buy your Woods 5 foot blade. How much did it cost?
Thanks
John
   / BX2200 3pt grader blade #6
BXMMCC... Thanks for the information. I live near Pittsburgh so I am quite a ways from Intercourse, PA. I will look for a dealer in my area.
John
   / BX2200 3pt grader blade #7
<font color="blue"> I can't turn the blade around with out removing because it hits the lift arms. </font>
Just off the top of my head--How about cutting off a little at the corners of the upper portion of the blade moldboard and, or shorten the toplink a little--Ken Sweet
Sweet Farm Equipment Co. *Inexpensive Nationwide shipping*
   / BX2200 3pt grader blade #8
Yup, that what I did, bought an old used 6' blade and shortened it to 5. My brother cut the top corners of his so his blade would spin around as well. Works great.
   / BX2200 3pt grader blade #9
Trimming the blade is possible I suppose unless you have to trim off a huge chunk. How old is your BX? Some of the early models 2000 for example had a modification that the dealers could do later on to help with some implements.
If angle of the arms is the problem and they aren't down on their stops, or adjusted downward as far as possible, couldn't you run the back tires on something to raise the rear end to allow you to pivot it, so the 3pt hangs more? I had a BX for awhile and there were usually some shenanigans involved in putting implements on it. It is not really a Cat 1 it's a Cat 1*
* 1. Buy a Quickhitch
2. Get a Back Brace
3. Put all implements on dollys.
4. Find really strong neighbor or have your other backhoe handy
5. Have salesman show you over and over and over how to put on implements until he gives you a QuickHitch for free! /forums/images/graemlins/grin.gif
del
Kubota L35, JD 4210 (soon), JDGT235, Ford 1710 (leaving, sob...) Blades, Buckets, Hoes, Scrapers, Crunchers other assorted toys.
Hours on machines about 1600, hours on operator about 455,000. Machines all in good shape, operator needs TLC. /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
   / BX2200 3pt grader blade #10
I purchased a KingKutter 5' grader blade from Tractor Suppply Company ($220.00). It has plenty of room to spin completely around. I've been impressed with the performance over about 20 hours on claiche as my BB has set idle since I bought the grader. Yesterday, after I graded a couple hundred yards of roadway, I did notice a little wear starting around the pin hole. Guess I'll weld a bead around the hole and harden things up a little.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
Zero Turn Mower (A59231)
Zero Turn Mower...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
