BX22 engine question
/ BX22 engine question #1
jpr62902
Platinum Member
After doing my 100 hour service, I was looking over the engine to see if everything was in good shape, and I noticed a nut missing over a strip of metal that is attached over the injectors. Attached is a pic of this. Anybody know what this is? Thanks for your help!
/ BX22 engine question #2
There should be a black wire with a red stripe on it connected to that bolt. Should be your glow plugs. Good luck. Rich /forums/images/graemlins/smile.gif
Looks like you're dead on, Rich. Thanks! Explains why the thing was hard startin' in the colder temps.
Now, question #2. I found the glow plug wire, but there's also a white wire with a plastic connector on it. Anybody know what this is? Pic attached.
/ BX22 engine question #4
Mine does not connect to anything eather,but mabe its for test insterments at the dealer ? Hope starts better in the cold. /forums/images/graemlins/grin.gif Rich
Okay, Rich. You're getting a little slow here. This time it took you 19 minutes to answer my question when before it only took you 10. /forums/images/graemlins/grin.gif
Seriously, thanks so much for your help. 3 cheers to you and TBN!
/ BX22 engine question #6
Starting to get tired running up & down the steps to look.Had to take a brake /forums/images/graemlins/grin.gif
/ BX22 engine question #7
I am glad to see that someone else has dirt on their engine and it does not look like it was just waxed.
/ BX22 engine question #8
I was gonna say almost the same thing but on the flip side. It needs a bath! /forums/images/graemlins/grin.gif
/ BX22 engine question #9
i have the same white wire w/plug not attached.
my dealer said it is not used on the BX.
You guys are HUGE! I just "reconnected" the glow plug bar and the old BX fired up quicker than the day it came to my door (and it's about 30 degrees outside). Thanks again!!!
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
Kubota M6950 (A64127)
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
Cultamulcher (A66408)
