BX1860, considering a quick-hitch system
/ BX1860, considering a quick-hitch system #1
ds10
Charlestown, NH
Kubota LX2610
I've had my BX1860 for almost 6 months. The only thing I've had on the three point hitch is a towing rig (triangle with a 2" ball and a 1 7/8" ball and a place to connect a chain as needed - this has been a really useful attachment). Now I'm thinking about a pine straw rake and will eventually wind up with some other items. I'd really like to consider a quick hitch system and see several of them on the market. There's one that's mentioned on this forum, but it appears to have some issues with top link distances. There's a few from Speeco, and I've seen others.
I'd like to get some feedback on which units are worth looking at, which are total crap, and which folks have found to be easy to work with.
At some point, I'll consider buying or renting various attachments, and I have read that not all are compatible with these quick attachment setups. When I was shopping for my tractor, I did consider a Deere, and they were pushing their quick attach 3 point setup too. Must be something to this? After putting on that first towing hitch setup, I could see why folks would consider a quick attach. Took a lot more work than I'd have expected!
Thoughts? Comments?
/ BX1860, considering a quick-hitch system #2
If you are going to be renting implements the Pat's quick hitch would be the most adaptive to all implements. They do not require the pin spacing to be the same and also do not require adapter bushings. They may (probably) will require a longer top link since they move the lift point back 3 - 4 inches.
What happens with Pat's setup when using an attachment that doesn't really have a top link, like this pine straw rake or rakes or blades that have a similar setup where there's simply a triangular frame on the attachment? Does the attachment wind up tilted forward (and upward, I guess) or is there some other thing that has to be inserted to make up the distance to the top attachment point?
/ BX1860, considering a quick-hitch system #4
I think we need to clarify terminology.
A Pat's system is NOT a Quick Hitch. It simply converts the end of your 3pt arms to open hooks that can be latched. You still need a top link and it has to be manually hooked/unhooked and adjusted to fit.
A Quick Hitch attached the top link to the QH frame and it is never unhooked. The QH frame stays on the tractor. To hitch to an attachment you simply back up to it properly and pick it up with the 3pt.
Pat's is more versatile because the attachment needs no modification. A cavaet there is I've heard people say they have an attachment that the Pat's won't work on because of structural interference.
A QH is a LOT easier to use but requires all attachments conform to it's dimensions.
For a BX or any SCUT sized tractor I don't think you need to worry about brands of QH. The tractor isn't powerful enough to tear them up. Move into the CUT sized tractors and that changes. I bent a Northern Tool QH with a 30hp CUT tractor.
/ BX1860, considering a quick-hitch system #5
They all do have a top link attachment point. The top link goes between the tractor and the top of the triangle or post on the implement. Look at the video still picture on your pine straw rake link and you will see the top link connected.
One possible cause of confusion: I've known several people who keep a pre-adjusted top link on each implement, and when they don't have a 3pt implement connected, there is no top link on the tractor. Most people just have one top link that stays with the tractor.
Bruce
/ BX1860, considering a quick-hitch system #6
If you go with PATS easy change you will need a longer toplink.
2019 BOBCAT T595 SKID STEER (A65053)
2019 BOBCAT T595...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
School bus (A64194)
School bus (A64194)
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2002 Freightliner School Bus, VIN # 4UZAAXAK52CJ75416 (A65563)
2002 Freightliner...
