Bx1500 stopped running
/ Bx1500 stopped running #1
fbc781
Raleigh, nc
bx1500 kubota
BX 1500 started blowing black smoke lost power I shut it off I have not been able to start it again. I have replaced both fuel filters the air filter both glow plugs and drain the tank nd put fresh diesel in it. still won't start, cranks fantastic, just does not even try to start
/ Bx1500 stopped running #2
There is a solenoid that shuts the tractor down. Any chance this is stuck in the off position? For a vague reference, I think its on the left side, about the middle of the engine but maybe a little more towards the back. Its a little bigger around than a roll of quarters. Normally you hear it click about 10 seconds after you shut the machine down. The click is when it returns to the on position.
I know thus Illinois that you are talking about and yes it is functioning properly
I loosened the two injectors at the motor one at a time they are both getting fuel
I have fuel and compression but still doesn't even try to start.
Maybe electrical ...but what
/ Bx1500 stopped running #7
Black smoke generally means over fueling. How many hours? Could be bad injectors or something else fuel related.
Hour meter quit yrs ago
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
FEED TANK (A63290)
FEED TANK (A63290)
CAT 140M Motor Grader (A64047)
CAT 140M Motor...
Case IH 950 Planter (A63118)
Case IH 950...
Hydraulic Auger Bits (A61572)
Hydraulic Auger...
