BX weight lifting test
/ BX weight lifting test #21
I think it is wise to remember that when we are seeing how much can be lifted by our machines, they can fail the test in a very expensive way.
/ BX weight lifting test #22
I run my BX2370 at 2500-2700 rpm, if I drop to 2000rpm I find it tends to labour a bit with a decent load such as wet builders sand, in the bucket (Kubota 4:1), doesn't seem to make much difference to the 3PL.
/ BX weight lifting test #23
I find BX max pressure is established at <>2000 RPM, increasing RPMs beyond that does not lift more just speeds up actions. I raised my pressure to 2000 PSI so can lift a little more. Never really tested comprehensibly like the OP. I assume everybody knows to get the weight as close to the tractor as you can to maximize weight capability. I can lift a lot more with a chain anchored just under the curl cylinder. I use bucket mounted forks. The FL attachment that replaces the bucket will lift more being closer to tractor.
Ron
/ BX weight lifting test #24
The dealer told us to run at 3000 but it sounds harsh, it sounds happy at the range I am using, I appreciate the pressure info though.
Rivinius R600C Spreader Skid Steer Attachment (A61567)
Rivinius R600C...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
CONSTRUCTION 4 ATTACHMENTS-XTREMEDUTY 48" FORKS (A62130)
CONSTRUCTION 4...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
2006 CATERPILLAR 928GZ WHEEL LOADER (A62129)
2006 CATERPILLAR...
TORO TIMECUTTER SS3200 ZERO TURN LAWNMOWER (A62131)
TORO TIMECUTTER...
