BX skid plate?
/ BX skid plate? #1
newtattoobob
Northeast Ohio
Kubota B2650, Kubota BX1850, RTV900XT Worksite, Kubota U17,1942 Farmall H, 1950 Ford 8N
After spending 4 hrs today replacing the hydro fan on my bx1850, I think its time for a skid plate. Most of the time I have the mmm attached. Are any of the plates, bro tek, bxpanded, compatible with the mmm? Any pros or cons to one or the other? Thanks
/ BX skid plate? #2
I have the factory skid plate on mine. Works great but the price K wants for it I would have made my own. Very simple bends with four holes.
/ BX skid plate? #3
I just installed the bxpanded plate on my bx25d, and it was really simple. However, it will not fit with the mower on. In fact, the back end of it hangs on the mower lift arms. Since I don't mow with the tractor, it works for me. Removal and reattaching the plate are easy enough that it should not be a deterrent to timely changing of filters and other maintenance. Maybe the Brotek will do what you need.
/ BX skid plate? #4
+1. I just put the bxpanded on my 25d and it could not have been easier
/ BX skid plate? #5
Mine is a BX2230, about 10 years old. The Bro-Tek one bolts on and stays on. There's a hole for the mower drive shaft, although mine rubs some. No idea about the newer ones, but I bet that is the same design point.
/ BX skid plate? #6
BXpanded on mine, easy on&off . But it's not a skid plate, it a belly protector that protects when the mmm is off.
/ BX skid plate? #7
I have the BX expanded on a bx 24 . I cut a half acre of bamboo down with it , I never had a problem , If I didnt have it I wouldnt have lasted 20 minutes
/ BX skid plate? #8
I also highly the BXpanded skid plate. I also use a MMM and I install the skid plate when the MMM is off.
/ BX skid plate? #9
I broke the HST fan even with the MMM on, so I put Bro-Tek on both of ours. both Bro-Tek and Bxpanded make great products..
/ BX skid plate? #10
Bxpanded on my 2360 ANYTIME the mower is off. Kit has two studs you install on initial install. Once those are in place you slide the front of the plate over those and clip the back to the mower lift arms, raise and lock in place. Super slick.
/ BX skid plate? #11
How's the fit with the bro tek and with the mid mount mower on? Is air flow sufficient?
/ BX skid plate? #12
I went with the Bro-tek and think it does a nice job. I drive over pretty rough stuff, hard into debris piles etc. I don't have a MMM so can't comment on compatibility.
Ford 8210 (A60462)
Ford 8210 (A60462)
1997 FORD F-350XL TRUCK (A64276)
1997 FORD F-350XL...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
2006 IMT 16000S3 Knuckleboom Loader Crane (A61573)
2006 IMT 16000S3...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
