Oil & Fuel BX oil change
   / BX oil change #21
If you use a K&N HP 1006 filter, the end has a 1" bolt molded to it.
I use a 1" socket with a 6" extension and my ratchet is clear of all side obstructions. The side panels won't need to be touched, let alone the brush guard!
   / BX oil change #22
I want to do an oil change on my bx. It has a brush-guard on the front and I can't see how to remove the plastic surrounding the engine without removing the brush-guard. Is removing plastic necessary for an oil change? Does the brush-guard also need to be removed? Any tricks would be appreciated.
U don't have to remove any of this stuff to do an oil change.
   / BX oil change
Well I got it changed and did not remove the panels. The screws holding it on have plastic handles on them, and the brush-guard is held on by standard bolts like the picture above. Removing it wouldn't have been hard, but I wanted to leave them on. This summer I will take it off and give it a good once over - just too cold now.
   / BX oil change #25
I made the mistake of having Messicks do a 50hr service, now i got a bill from them for $680.00 so make sure you learn how to do it your self!
   / BX oil change #26
Would love to know what all was included in the 50hr service that would cost $680.00.
   / BX oil change #30
Actually, that price has been reported here for most dealer's 50 hours service. That sounds about right.
Learning to do simple fluid and filter changes at home will save hundreds and hundreds of dollars.
2014 JCB 930 (A53317)
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
