Oil & Fuel BX oil change
/ BX oil change #41
I made the mistake of having Messicks do a 50hr service, now i got a bill from them for $680.00 so make sure you learn how to do it your self!
PM me your name. If all you had done was an oil change... I'll be calling you with a nice credit. The typical full service on a BX is half that.
I'm gonna bet that Messicks shop hour rate is north of 100 an hour, but still, it doesn't add up.
Its $68 right now (With a few exceptions). We're on the lower 1/3 of what you'll see around us. Our local CAT shop is $125.
/ BX oil change #43
As Paul Harvey says "Now for the rest of the story".
Messicks has a good reputation from their customers on this forum. I don't think they would have with this kind of charge for a 50 hour service on a BX. As I said before, I'm waiting on the itemized or corrected bill.
/ BX oil change #44
Still waiting? :D:D
/ BX oil change #47
Hey, ive bin busy, but here goes: the story is: had a little warranty work done and while they had it they did the 50 ser. The bill was not really itemized but here goes:the oil and filters came to around 56.00. was told to pick and deliver was 270.00 -warranty doesn't cover this, the rest was labor which says 289.00. I think i paid for the warranty work. The neighbors that have kubotas said the price sounded like normal. Was disappointed that they didn't check front axle, it was 1 1/2 qt low, so i filled it up. Its hard to complain about typical warranty work! I still love my tractor and yes i still like Messicks.
/ BX oil change #48
Hey freddy, thanks for getting back with the details.
Kinda figured from the get-go that there was some trucking charges involved, as well as warranty work. Some of the rather high quotes we've seen posted here for 50 hour service, and yes, there's been some high quotes, often fail to mention the delivery.
It's a good reminder that warranty does NOT obligate the dealer to fetch or return your tractor. Pickup/delivery for a couple of 50 miles round trips is going to cost serious money. I remember the dealer on my BX, at the time, making sure I understood that the warranty began at his shop's front door.
/ BX oil change #49
I don't know how common this is, but Davis Farm Supply offered to send a guy down to do the 50 hour service on our M8540 on site for a cost of $100 plus materials. My son did it instead, but I thought the price was a fair one.
/ BX oil change #50
One trip. Makes good sense to me.
/ BX oil change #51
Warranty work labor should be free. Hope you find out what the $289 is for and let us/me know.
/ BX oil change #54
sorry for not getting back..:( but it wasn't itemized, they lumped it all togeather, warrenty and all. I think i paid for the warreanty work. I gave up and left it go. live and learn:D
/ BX oil change #55
Well, I spent several hours today servicing my (new to me) BX2200. I changed the oil and filter- new Wix filter and Shell 5w40 synthetic oil.
Replaced HST Filter and 2.6 gallons of SUDT2, and cleaned suction strainer. Replaced engine fuel filter, but the fuel tank was almost full, so I couldn't replace the fuel pump filter.
Replaced the air filter to engine hose.
Replaced both upper and lower radiator hoses, and put in new lifetime Peak anti-freeze.
Removed the rear 3 point lift arms and turnbuckles, along with the top link because they serve no purpose to me.
Cleaned and greased the mmm.
Man that was a bunch of work for a 60 year old man, and it doesn't run a bit better, but I sure feel better about it.
I spent less than $200, so I guess I saved over $480 right?
K
/ BX oil change #57
K
K, changing that filter is easy. Take the top two bolts out of the fan shield and swing it down. Clamp the hose as far back as you can reach with a small vise grip. Change away. I am in the process of my 400 hr. I have decided I am going to move the after pump filter down below so I do not have to pull the engine shroud to do only that. Using a filter tool on a 3/8 drive ratchet and long extension I can remove the oil filter in spite of the shroud being in the way. Those two items are sure a stupid engineering decisions on Kubota's part. Thinking on replacing the two bolts with pins and hairpins also. Next time I change the fuel filters I am installing a valve in the hose from the tank. I am a lot older than you and have to look at ways to make it simpliar and aesy as I do not do well laying on my back and working overhead.
/ BX oil change #58
Thanks Seabee. I hadn't thought of trying to clamp the fuel hose upstream of the filter. Next time I have the mmm off, I'll try your suggestion.
Have you ever had occasion to pull the main engine pto shaft? (The shaft between the engine and the transmission.) It has a dust boot on each end, and one of my boots is torn in half. I'm just wondering how big and bad a job that is.
K
/ BX oil change #59
K
K, haven't had to do that yet. I checked in my shop manual and it does not discuss removing the shaft in either the engine or transaxel sections. When I am under there tomorrow I will see if it is obvious how it comes apart.
Ron
/ BX oil change #60
I've used a zip-tie or cable-tie or whatever you call them thru the bolt hole to cinch the filter bracket in place. Done this since the first time I changed the filters and discovered this engineering work. ( OK, I got mad and threw the bolt across the yard after the fifth attempt at lining everything up)
Anyways the filters never came loose, just cut the tie and swap the filters. Install new tie. DONE.
I also use the visegrips to pinch off hose. Keep meaning to install a shut off valve before the first filter.
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2018 Cam Superline Trailer (A62679)
2018 Cam Superline...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
(5) Husqvarna Weedeaters and Leaf Blower (A65579)
(5) Husqvarna...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
