BX engine horsepower
/ BX engine horsepower #1
tjb393
none yet, in the process of searching right now
So my BX2380 will be getting delivered tomorrow and just went on to the kubota website to look at something and noticed that the engine horsepower ratings are now lower than what I have listed in my brochure. The 1880 is listed as 16.6, the 2380 at 21.6, and the 2680 at 24.8. Does anyone know if there's any truth to this or just an error of some sort?
/ BX engine horsepower #2
https://www.kubotausa.com/docs/default-source/brochure-sheets/new_bx80.pdf?sfvrsn=233d3332_2
delete the "new_" and the old brochure turns up with the old ratings clearly listed.
https://www.kubotausa.com/docs/default-source/brochure-sheets/bx80.pdf?sfvrsn=233d3332_2
Both claim the rating was obtained using SAE J1995. Something's funky.
I have no idea as to what prompted the change or why they're being sly about it.
I noticed that with the "new" as well. I was just looking something up and didnt have my brochure with me and noticed the change and thought what the heck is going on. It even says it on the website when you're going to check out the bx series. It says 16.6-24.8 hp
/ BX engine horsepower #4
All the BXs will lose traction or turn over before they run out of HP. Weight of tractors and implements along with ground clearance are the primary factors to consider. The HP and size mowing deck may be a consideration but I doubt very much. Also HP and size of bush hog/rotary mower and speed to cut might make a slight difference but these are not usually BX issues.
/ BX engine horsepower #5
PTO HP didn't change. I'm just curious as to what prompted a 1.4HP downgrade of gross engine HP on the entire line except the 2680, which only suffered a 0.7HP downgrade.
Did Kubota fluff the numbers to make the model naming work and get caught? Someone out there is petty enough to sue over 1.4HP, even the kind that doesn't matter, I'm sure.
Did something happen with emissions that caused them to downrate the engines to burn cleaner? Unlikely, since PTO HP didn't change.
Were their initial test results flawed for some reason? You'd think that would have been worthy of a press release, instead of this quiet respec.
I'm in it more for the mystery than anything else. I'd love to have a little BX for the smaller yard tasks. Can't afford one and my "big" tractor right now. So I have no skin in this.
That's what I'm saying. 1.4 horsepower isnt necessarily a big difference but it's not something that's small either when they name the tractor a 2380 and it's not even 22 horspower. It's more of why are they trying to slide this in there like that when nothing else spec wise has changed
/ BX engine horsepower #7
It gets better! I was poking around the BX part of the site, and the 1880 is now the 1880V in the build and price tool. As of time of writing all other model numbers seem unchanged, and the "V" only appears in the sidebar that lists your selections.
They've also done something funky to the BX23S's build page. All the non backhoe options are gone, and I think there's an extra "R" mixed in with the naming, but that model's name has always been alphabet soup, so I'm not sure.
/ BX engine horsepower #8
'V' means a valve is part of the tractor, that's a normal model code. not new. All BX23's have alway had backhoes. There has never been a non-backhoe version. R is the tire that ships on the tractor.
/ BX engine horsepower #9
OK. So what's the story on the engine power change? Inquiring minds want to know.
/ BX engine horsepower #11
Wonder if they switched from gross intermittent to gross continuous or net intermittent?
I looked up the SAE test they use to see if they changed it recently and doesn't appear so, I think its latest update was about 2014.
/ BX engine horsepower #13
I bought my bx23s last year. The brochure listed the horsepower at 23. I researched the stand alone D902 engine on Kabota's site and it was listed as 21.6. As far as I could tell the engines were identical. I'm guessing Kubota needed to get their info on the engine straightened out.
/ BX engine horsepower #14
The same engine can be rated for different outputs, there are 4 ratings they can use also (gross intermittent, net intermittent, gross continuous, net continuous) and there are different ratings based on rpm and application.
Since it appears the PTO hp stayed the same I wouldn't worry about it, although I am curious what brought about the change.
LandHonor 7ft Double Leg Chain Sling (A60353)
LandHonor 7ft...
Box of Gauges and Valves (A60353)
Box of Gauges and...
2019 Freightliner M2 106 Altec AA55 55ft. Bucket Truck (A60352)
2019 Freightliner...
John Deere 1023E (A62177)
John Deere 1023E...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
UNUSED JCT 84" HYD DOZER BLADE (A62131)
UNUSED JCT 84" HYD...
