BX "Boulder Holder"
/ BX "Boulder Holder" #21
Re: BX \"Boulder Holder\"
I got it as part of my initial tractor purchase so the price was a little 'soft', but I believe it retails around $300. The skids for the blade were an additional $100 or thereabouts. A quick phone call to a LandPride dealer (locations on their web-site) will get you the price in your area ... they don't deal direct!
Patrick
/ BX "Boulder Holder" #22
David,
May I use your amazing picture of your BX2200 holding the rock on my Web site? I have not put my tractor page together yet, but I offer gardening, farming and other books through Amazon and want to offer tractor books also.
My site is www.yessiree.com. It's just a hobby site and not very fancy. Your photo would really dress it up.
Frank Dwyer
frank@yessiree.com
Re: BX "Boulder Holder"
Thanks for asking and by all means feel free to use it. Frankly, I assumed any pictures posted here were somewhat "public domain" anyway.
/ BX "Boulder Holder" #24
bare with me whilst I flounder about here:
How hard is it to mow with the FEL on?
Do you take it off to mow? Is it really practical to remove and replace or is it honestly a bit of a chore? does it take an afternoon or 10 minutes? Does it take more maintenance? does it steal power from the tractor?
Also, please answer all the questions I didn't know to ask!
Thanks!!! ;^)
Rogue
/ BX "Boulder Holder" #25
As another data point, I reciently bought a 7' land pride blade (same as the one in this thread but wider blade) without skids for $395. The 6' model was $350. There prices were at my local dealer in NH.
/ BX "Boulder Holder" #26
I always remove my FEL for mowing. Usually takes 2 minutes to remove and maybe 3-5 to reinstall
/ BX "Boulder Holder" #27
On my B7500 I mow with my FEL attached. Just watch out for the bucket, er, no real damage been done but my FEL has trimmed a couple trees, flowers & shrubs. I'm told it takes less than 5 minutes to attach/reattach the FEL but I'm constantly fixing a spot or twenty in the yard.
Bluegrass, Pick It Up!
/ BX "Boulder Holder" #28
Rogue,
Stumbled across this graphic that shows the Kubota 'quick-hitch' front end attachments ...
Patrick
/ BX "Boulder Holder" #29
I mow with the FEL on my BX. No problem, as long as you don't forget it's out there.
/ BX "Boulder Holder" #30
I would also add to all you boulder movers, be cautious, as the right shaped boulder can add a nice curve to the bottom of your bucket. Standard buckets are not designed for this type of use. Consider welding on a reinforcement to the bottom, or adding a bolt on cutting edge if it's an option. It's so much easier to do this then fix a warped out bottom edge.
With that said... BRING ON THE BOULDERS! /w3tcompact/icons/smile.gif
del
/ BX "Boulder Holder" #31
Roque the first time you remove and install it it will take perhaps 20 minutes but once you have gone through it you will take about 2 minutes off and maybe 5 or so to reinstall, occasionaly about 10 if I am not lined up good. It is about the same diffuculty (easy) as removing the MMM or reinstalling it--actually easier I think.
Yes you can mow with the FEL attached but it is about 560 lbs of extra weight squashing your grass, compacting your soil and I can assure you when you hit something with that FEL it is going to tear the crap out of whatever it is that get's hit. Hopefully it will not be a dog, kid, wife--keep them away from that loader and keep your fangles out of the holes the side pins go in when removing and installing lest thy wind up fangleless cuz that loader means buisness.
Some excellent BX sport, hide behind a bush while waiting for the neighbors to think you are not at home and when they start up there little LT run out and flip it with your loader, LT flipping, kind of like dwarf tossing. Gosh that was not very PC of me, hope I did not offend any one. J
/ BX "Boulder Holder" #32
We do Huffy tosses at Mountain Bike races sometimes!
Equally as fun, but more work (what pipes)
I should have listened to you in the first place when you told me to get the loader!
Rogue
/ BX "Boulder Holder" #33
I have a BX2200 and I do not mow with the loader on.
It is so easy to remove the FEL (about 3-5 minutes at a leisurley pace, no tools, no effort..seriously) that I take it off. The first time I took it off it took me about 10 minutes to put back on. This was due to the parking brake being on. I found that if you leave the tracor in neutral without the brake on it is much easier to install. This enables the tractor to move alittle and the loader and pins just slide right in without having to muscle it.
The maintenance is about 10 grease fittings.
It does not steal power from the tractor while mowing since you are not using the loader while mowing.
If you have trees it will be harder to mow with the loader on, since you must keep track of it while backing up etc.
You may just run the loader into a tree. I believe it would also reduce the ride quality, since the tractor would tend to bounce more back and forth with the loader hanging out front.
/ BX "Boulder Holder" #34
I mow with the loader on but i remove the bucket with the bracket i made. less trouble than finding a spot for the whole assy.2 pins and the bucket(or my other attachment0 is off.
2017 Metso Lokotrack ST2.4 Screen Plant on Tracks with Feeder (A65579)
2017 Metso...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
2016 P.J. Trailer Trailer, VIN # 4P5F8202XG1252798 (A65563)
2016 P.J. Trailer...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
