Grading BX and a boxblade
   / BX and a boxblade #1
shrekbelly
guys,
i have a large area that i'm going to renovate. first i must use a landscape rake, then cut down numerous sapplings (maximum diameter 2.5 inches). my question is, will i be able to tear the stubs and some roots up with a strong boxblade (either with the digging tine or rear cutting edge)?
thanks in advance, shrekbelly
   / BX and a boxblade #2
You're going to use a landscape rake BEFORE you cut down the saplings? I'm having a hard time visualizing how that works. I don't have a boxblade but in my experience with a backhoe a 2"+ diameter stump is going to stop your BX in its tracks, but it probably depends on the tree species and soil type.
   / BX and a boxblade #3
guys,
Maybe. Depends on their roots. I dislodged/uprooted several that size with my RatchetRake and later ran through some with the boxblade. They are/were what we call water sprouts here so came up pretty easy and the ground was slightly moist and mostly top soil.
The Ratchetrake did alot better because the teeth are really close together and grabbed them and pulled them out. The problem with the Boxblade was/is the space between the digging tines which let the BB slide past the unwanted subject without removing them. The strength part of tractor or BB should not be an issue, it's just getting the tines/teeth of the BB to grad them. Believe the blade may do the same thing, just slide over them. Just give it a try. If it doesn't work, come get my RR.:)
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
