BX 2350 Oil Question
/ BX 2350 Oil Question #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
Anyone use Rottla T-6 in their small Kubota tractors?
I always used the Kubota oil in this tractor when I owned it, I sold it to a friend and he want's to use the synthetic Rottla T-6, anyone see any problems with this?
/ BX 2350 Oil Question #2
I use it in my bx1860.
I don't see a problem switching. In the early years of synthetic they said you would cause leaks if you switched from conventional. Now I don't think it matters as much.
/ BX 2350 Oil Question #3
I've used it for ten years in my tractor and motorcycles...
/ BX 2350 Oil Question #4
Once I hit 50 hours I change to Amsoil. I have found that the engine is much quieter in the winter with the synthetic. Just my 2 cents worth.
/ BX 2350 Oil Question #5
I use it in my BX25. No issues.
/ BX 2350 Oil Question #6
I use T6 also, almost 800 hours. No problems
/ BX 2350 Oil Question #7
I switched to T6 a few years ago and noticed immediately that it was smoother/quieter, especially at low rpm.
/ BX 2350 Oil Question #8
I have a BX2360 and am getting ready for my first oil change. Is Rotella T6 SAE 5W-40 OK to use for this change. I live in Massachusetts and my tractor is garaged ?
/ BX 2350 Oil Question #9
Not a oil expert. In general make sure it has the right specs such as
(Below 32°F use SAE10W or SAE10W-30 or 10W-40) (32°F to 77°F use SAE20 or 10W-30 OR 10W-40) (77°F and above use SAE30 or 10W-30 OR 10W-40)
To get real detail and perhaps more important the specs in your manual may be similar to
(API Service Category: CJ-4, CI-4 Plus, CI-4, CH-4, CF-4, CF, CE, CD, CC/SL, SJ)
As far as Google goes the numbers and info above are correct for your unit. Just find the specs for your unit year made to make sure. Rotella brand has a great reputation.
/ BX 2350 Oil Question #10
Yes it OK for your tractor!
Actually better than you really need.
Factory fill is 10W30 conventional oil.
Kubota or Shell Rotella 10W30 would be perfectly adequate for your garage-kept tractor at a lower cost.
But,since we love our tractors,why not use the good stuff?
Good Luck!
/ BX 2350 Oil Question #11
Good Luck!
This is new to me , T6 used to be 15w-40 dino..no? Now 5w-40 syn, is Kubota Ok with this ? Is this Ok for my B2920?
Thanks.
/ BX 2350 Oil Question #12
Rotella T6 5W40 is an excellent choice that Kubota would approve of and your B2920 will be very happy with it.
I don't think T6 was ever 15W40 grade.
The Kubota operators manual recommendations are woefully out of date.
Good Luck!
/ BX 2350 Oil Question #13
Good Luck!
Your right, I think it was just Rotella T..
2004 John Deere 544J Articulated Wheel Loader (A64553)
2004 John Deere...
Towable Air Compressor (A64553)
Towable Air...
EZ - Trail 672 Header Trailer (A66285)
EZ - Trail 672...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
40ft Shipping Container (A65579)
40ft Shipping...
INGRESOLL RAND 80 GALLON COMPRESSOR (A65643)
INGRESOLL RAND 80...
