BX 2350 Oil Question
/ BX 2350 Oil Question #1
Kubota 2350
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
Anyone use Rottla T-6 in their small Kubota tractors?
I always used the Kubota oil in this tractor when I owned it, I sold it to a friend and he want's to use the synthetic Rottla T-6, anyone see any problems with this?
/ BX 2350 Oil Question #2
I use it in my bx1860.
I don't see a problem switching. In the early years of synthetic they said you would cause leaks if you switched from conventional. Now I don't think it matters as much.
/ BX 2350 Oil Question #3
I've used it for ten years in my tractor and motorcycles...
/ BX 2350 Oil Question #4
Once I hit 50 hours I change to Amsoil. I have found that the engine is much quieter in the winter with the synthetic. Just my 2 cents worth.
/ BX 2350 Oil Question #5
I use it in my BX25. No issues.
/ BX 2350 Oil Question #6
I use T6 also, almost 800 hours. No problems
/ BX 2350 Oil Question #7
I switched to T6 a few years ago and noticed immediately that it was smoother/quieter, especially at low rpm.
/ BX 2350 Oil Question #8
I have a BX2360 and am getting ready for my first oil change. Is Rotella T6 SAE 5W-40 OK to use for this change. I live in Massachusetts and my tractor is garaged ?
/ BX 2350 Oil Question #9
Not a oil expert. In general make sure it has the right specs such as
(Below 32°F use SAE10W or SAE10W-30 or 10W-40) (32°F to 77°F use SAE20 or 10W-30 OR 10W-40) (77°F and above use SAE30 or 10W-30 OR 10W-40)
To get real detail and perhaps more important the specs in your manual may be similar to
(API Service Category: CJ-4, CI-4 Plus, CI-4, CH-4, CF-4, CF, CE, CD, CC/SL, SJ)
As far as Google goes the numbers and info above are correct for your unit. Just find the specs for your unit year made to make sure. Rotella brand has a great reputation.
/ BX 2350 Oil Question #10
Yes it OK for your tractor!
Actually better than you really need.
Factory fill is 10W30 conventional oil.
Kubota or Shell Rotella 10W30 would be perfectly adequate for your garage-kept tractor at a lower cost.
But,since we love our tractors,why not use the good stuff?
Good Luck!
/ BX 2350 Oil Question #11
Good Luck!
This is new to me , T6 used to be 15w-40 dino..no? Now 5w-40 syn, is Kubota Ok with this ? Is this Ok for my B2920?
Thanks.
/ BX 2350 Oil Question #12
Rotella T6 5W40 is an excellent choice that Kubota would approve of and your B2920 will be very happy with it.
I don't think T6 was ever 15W40 grade.
The Kubota operators manual recommendations are woefully out of date.
Good Luck!
/ BX 2350 Oil Question #13
Good Luck!
Your right, I think it was just Rotella T..
213091 (A64276)
213091 (A64276)
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
1999 FREIGHTLINER FLD70 ROLLBACK (A65643)
1999 FREIGHTLINER...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
