Buying/Pricing/Hours question on JD 3720
/ Buying/Pricing/Hours question on JD 3720 #1
Boulderz
MS, VT
JD
Hi, 1st post!
I am considering a 2006 JD 3720 with e-hydro transmission, 300cx loader with quick detach bucket, 447 backhoe, and R4 tires. Tractor has 2400 hours, runs great according to seller, with all recommended service intervals met according to seller. Includes winter chains for rear tires. Rear tires will need to be replace before too long. Needs new seat.
Asking price is $15K.
My question is about price and hours. It seems like a fair price but I am wondering about the hours. Was owned by a resort type place and most likely used for general maintenance, horse barn cleanup, etc. Obviously used for some digging.
We just purchased about 75 acres with lots of steep hills and a 1/3 mile steep driveway. I plan to use the tractor for plowing, snow blowing, stumping, moving brush, etc. Land is mostly wooded and want to clear some. Property maintenance. I have never owned a tractor of this calibur and am not sure if buying this tractor with this amount of hours is a bad idea..
Would like your opinion.
/ Buying/Pricing/Hours question on JD 3720 #2
as long as its in good shape, doesn't have cracked plastic/ worn pins ect. check the hoe for worn pins ,look for oil leaks , 2400 hours would not scare me at all 15,000 is a deal for that with the hoe as long as its 90% there is going to be something besides the seat just look . front axle seals are common leakers not to expensive but a cost . look under for oil leaks I just repaired a 4400 with 3400 hours leaking from seal of front drive shaft 30? for seal 200 ? for oil and filter 16 hours to split the tractor and put back together
(1) UNUSED 2.5" RATCHET STRAP (A60430)
(1) UNUSED 2.5"...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A60432)
UNUSED RAYTREE...
