Buying Advice Buying first CUT
/ Buying first CUT
I'm happy to say I made a purchase over the weekend. I really would have liked that 4410 with the loader and MMM, but my wife didn't want us to spend that much right now. So instead, I broadened my search all the way to St Louis and found a 2005 JD 4310 with e-hydro, 4x4, and just 115 hrs. When I drove down to see it, it was garage kept with a cement floor and in perfect condition - all the factory paint marks on the bolts was still clear. The owner was one of the nicest guys you'd ever meet and had only been using it for mowing with a rear finish mower. I bought it for $10,800, and picked up an almost new 72" MMM deck on the ride home for $900.
The unfortunate things about it are that it has no loader, no mid pto, no mid mower lift kit, etc. So I'm going to start piecing all of that stuff together after I do the research and figure out exactly what I need. I'm trying on to figure out all of the part numbers.
Anyways, I'm super excited about my purchase and I've already put two hours on it doing some much needed gravel work with an 84" rear blade which it handled extremely well! After using it now for a couple of hours I'm glad I didn't go any smaller, it's the perfect size for my needs.
I'll post pictures when I can.
/ Buying first CUT
/ Buying first CUT
The first picture in the dark was taken tonight after I got done working with it and putting it back in my garage. The other photos were taken by the seller at his home when he was trying to sell it. It's quite a machine!
/ Buying first CUT #35
Congrats on the purchase. You should get some good use out of it. As you probably know, you are in for some considerable additional expense, especially since it's green and yellow, to add a FEL, mid PTO, lift, etc. that you might see a need for.
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
