buying advice-1520
/ buying advice-1520 #1
stevecas
Case 530ck
Ford/new Holland 1520
I'm looking at 1995 1520 with bucket and backhoe, approx.4650 hours, 4wd and in decent shape. what is the good, the bad and the ugly? I will be using it for light work on a 10 acre piece of property.
Thanks
/ buying advice-1520 #2
Is it a Ford 1520 or a NH T1520?
Different tractors.
From what I can from tell pictures it’s a Ford. Listed as Ford/New Holland. Trying to set up a day to look at it. Listed for $14,500.00
Thanks
/ buying advice-1520 #4
1995 was the last year for production of the Ford 1520, produced by Shibaura of Japan.
New Holland compact tractors are produced by LS of Korea.
Not sure how easy it will to be obtain parts for the Ford after 26 years nor in the future. To me you are considering an orphan. 4,650 hours is pretty high. $14,500 seems high to me. Can you wrench it yourself? I would have a tractor mechanic check it out thoroughly.
Determine if it is 2-WD or 4-WD.
It is a light tractor for use on ten acres.
Kubota's equivalent is the Kubota 'B' series. Kubota dominates tractor sales in the 2,000 +/- tractor weight category.
YouTube Ford 1520 videos: https://www.youtube.com/results?search_query=ford+1520+tractor
Ford 1520 Dimensions​
Dimensions
Wheelbase:63 inches
160 cm
Length:112.4 inches
285 cm
Width:48.4 inches
122 cm
Height (ROPS):84.3 inches
214 cm
2WD Shipping weight:2156 lbs
977 kg
4WD Shipping weight:2278 lbs
1033 kg
2WD Ground clearance:11.6 inches
29 cm
4WD Ground clearance:11.2 inches
28 cm
2WD Front tread:39.2 to 50 inches
99 to 127 cm
4WD Front tread:42.5 inches
107 cm
2WD Rear tread:38.1 to 51.8 inches
96 to 131 cm
4WD Rear tread:44.1 to 47.1 inches
112 to 119 cm
/ buying advice-1520 #5
I've looked at them and really like them, only issue I found seems to be parts availability can be hit or miss. Most service parts aren't a problem, but there has been some difficulty getting repair parts, recently it was brake components for a neighbors 1520 or 1720 (can't remember).
The factory loader capacity isn't bad but a bit lower similar sized newer equipment. Is this a gear or HST?
Not sure how pricing is in your area, but price seems high for the hrs on the machine. Although these days prices on all equipment is high. If in really good condition it might be worth it because of the bqckhoe.
I really want a 2120 HSS!
Sent from my SM-G715U1 using TractorByNet mobile app
/ buying advice-1520 #6
Not sure how easy it will to be obtain parts for the Ford after 26 years nor in the future. To me you are considering an orphan. 4,650 hours is pretty high. Can you wrench it yourself? I would have a tractor mechanic check it out thoroughly.
It is a very light tractor for use on ten acres.
Dimensions
Wheelbase:63 inches
160 cm
Length:112.4 inches
285 cm
Width:48.4 inches
122 cm
214 cm
977 kg
1033 kg
29 cm
28 cm
99 to 127 cm
107 cm
96 to 131 cm
112 to 119 cm
Yes, but the same tractor was produced under the Hew Holland name until the late 90's, I believe 98.
I would put them closer to a Kubota std L in size/capacity.
EZ Trail 3400 (A63688)
Rake Master CR7-72G (A64119)
Rake Master...
Fuel Tank (A64119)
Fuel Tank (A64119)
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
(2) HAY TEDDER WHEEL RAKES (A64280)
(2) HAY TEDDER...
