Buy syncrowave 200?
/ Buy syncrowave 200?
Here in the Oknanagan area stuff is even more expensive. :(
This tig welder is one of 4 which were on the market in the past half year. Not more. And I do have alerts for Kijiji and a bunch of other pages.
Here, I’ll buy your 351 for $900. That sounds like a good deal for both of us right? I get a good deal and you made $50:laughing:
/ Buy syncrowave 200? #13
Thanks for the offer. I'll get back to you on that....
Being in the Okanagan you have better access than me to all the Alberta oil sands goodies for sale.
/ Buy syncrowave 200? #14
If it’s low hours, say under 100 and it’s has the tigrunner wheel kit, then I’d say it’s a good deal for $1300 Canadian. IIRC, if you push the dig button when you turn it on, it will display how many hours it has. The manual will tell you for sure.
I have one, and while it is power hungry, it welds very well. It will need a 50 amp outlet, and even then can pop the breaker when run wide open. They are also pretty bulletproof. You don’t see many problems with them like some of the other syncrowave machines. Don’t expect to tig 1/4” aluminum with it.
I thought I read somewhere that it did 1/4 aluminum and steel:confused:
/ Buy syncrowave 200? #16
Small pieces of 1/4”, yes. Large plates, no.
And for the breaker, I plan on putting in a 50 or 60 amp anyway...
/ Buy syncrowave 200? #20
I’ve never hit the duty cycle limit. It has popped my 60 amp breaker a couple of times with the amperage set to 200a a/c.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2018 Caterpillar 308E2CR (A60462)
2018 Caterpillar...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2020 DRAGON ESP...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
