Buy syncrowave 200?
/ Buy syncrowave 200? #1
Tractorguy24
BC, Canada
Alright, im still looking for a tig. I found a miller syncrowave 200 for sale for $1300 Canadian. Air cooled torch and no bottle. Seems like the syncrowave has quite a few bells n whistles? What do you guys think of the price? Any input is appreciated!
/ Buy syncrowave 200? #2
I’m going off memory but that machine is Miller’s transformer machine. $1300c is an OK price. Read the manual a lot of Miller machines will tell
You the hours but I don’t know if that one does. If I recall that machine can take a spool gun too.
I shied away from it because I couldn’t move it without a crane or two people. But if that isn’t on your needs list give it a try- you won’t lose money at that price.
Verify it has the foot pedal- that’s a few hundred bucks.
Thanks for your reply, rneumann.
Yea it does have the foot pedal. The manual tells how to check the hours, but even if I knew them, it wouldn't tell me anything. I know how much hours on a tractor is a lot and what isn't, but I have no idea on a welder:D
And the weight doesn't matter. Im sure my old two fifty twin stick welder is a bit heavier:laughing:
/ Buy syncrowave 200? #4
The syncrowave 200 should be transformer based.
The syncrowave 210 is the inverter model (of questionable quality) that also runs a spool gun.
/ Buy syncrowave 200? #5
The price is good for "our" area. I paid $1750 CDN for mine. 13 hours with foot pedal, torch, cables and a small bottle of argon.
Sold it a couple of months later for $2250CDN when I found a bigger machine.
Thanks for your reply Dave!
So you're saying the quality of the 200 is not questionable (it is a transformer)?
This is probably a stupid question, but Why would you need a spool gun on a big? For Welding aluminium fast?
What did you do to it to make it worth so much more? let it live in your shop for awhile?
I know what you mean by the prices in our area:(
Ill probably keep the two fifty twin for heavy stick welding, so I don't need enormous amounts of power.
/ Buy syncrowave 200? #8
By "our area" I mean British Columbia. I built the cart for it but the buyer didn't need it so I kept it. He was happy to find such a low hour machine, still under warranty.
/ Buy syncrowave 200? #9
It’s just a MIG option. Aluminum or other metals would work with the spool gun. Miller, IMO, was making and marketing the machine as a high end homeowner/entry level commercial model that could do “everything.” That’s why they probably made the spool gun an option. Lincoln and others also make multiprocess machines.
/ Buy syncrowave 200? #10
Don't despair. There ARE deals to be had occasionally. I watch Used Victoria/Vancouver and set alerts for Kijiji BC.
Here's my $850CDN ($570 USD) 351 S'Wave after "cleaning it up".
Here in the Oknanagan area stuff is even more expensive. :(
This tig welder is one of 4 which were on the market in the past half year. Not more. And I do have alerts for Kijiji and a bunch of other pages.
Here, I’ll buy your 351 for $900. That sounds like a good deal for both of us right? I get a good deal and you made $50:laughing:
/ Buy syncrowave 200? #13
Thanks for the offer. I'll get back to you on that....
Being in the Okanagan you have better access than me to all the Alberta oil sands goodies for sale.
/ Buy syncrowave 200? #14
If it’s low hours, say under 100 and it’s has the tigrunner wheel kit, then I’d say it’s a good deal for $1300 Canadian. IIRC, if you push the dig button when you turn it on, it will display how many hours it has. The manual will tell you for sure.
I have one, and while it is power hungry, it welds very well. It will need a 50 amp outlet, and even then can pop the breaker when run wide open. They are also pretty bulletproof. You don’t see many problems with them like some of the other syncrowave machines. Don’t expect to tig 1/4” aluminum with it.
I thought I read somewhere that it did 1/4 aluminum and steel:confused:
/ Buy syncrowave 200? #16
Small pieces of 1/4”, yes. Large plates, no.
And for the breaker, I plan on putting in a 50 or 60 amp anyway...
/ Buy syncrowave 200? #20
I’ve never hit the duty cycle limit. It has popped my 60 amp breaker a couple of times with the amperage set to 200a a/c.
2020 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2020 Globe Trailer...
832641 (A61166)
832641 (A61166)
Auger and Bit (A60352)
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
TANK MANIFOLD (A58214)
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
