Bushings for quick hitch
/ Bushings for quick hitch #1
Stomper
Saskatchewan, Canada
2017 Kubota L2501
I picked up an Agri Ease quick hitch from a local farm supply store. I assume it's a chinese made unit. It is a catagory one but he quick hitch part is not. I assume from the measurements that its a catagory 3, bottom hooks can fit a 1.5" shaft and the top a 1.25". I thought it was a cat 2 so I have already ordered the cat 1 to 2 bushings. The cat 2 bushings have a 1.125" OD. Will that be too much slop in the lower hooks or will it be fine.
/ Bushings for quick hitch #2
Should be ok. I have the harbor freight qh. Same issue. I did not measure but the 1 to 2 bushing took out most of the slop and it seems ok from there. Make sure to get 2 for every implement you have.
/ Bushings for quick hitch #3
All of the QHs are this way. As you figured out you need bushings to go to cat 3 lift pins. Almost any ag store like TSC will sell these that do it in one step or two bushings to do it in two steps.
CountyLine Quick Hitch Bushing Kit, Cat 1 at Tractor Supply Co.
CountyLine Lift Arm Bushing, Cat 2-3 at Tractor Supply Co.
CountyLine Category 2 to 1 Lift Arm Bushing at Tractor Supply Co.
If the attachment has an open-ended lift pins then the first lint is the better long term solution. If the attachment has captive lift pins then you need to nestle the bushing.
/ Bushings for quick hitch #4
What it should be ... And what it actually is, is two different animals...
Dale
/ Bushings for quick hitch #5
As others said the QH standard specifies CAT3 size pins for all sizes of QH. Northern Tool has the bushings online, lots of farm stores have them around as well. I have them on most of my impliments & a stash on a shelf. There are a few impliments I havent gotten bushings on for some reason & they actually work fine. If I recall, putting bushings on the lower pins on my tiller would cause insufficient clearance for the lift hooks between the pins & frame (poor engineering by King Kutter). I could welds things in a new spot, but it works fine without bushings. I'll fix it right so bushings fit if/when the pins break.
Bush Hog 296 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
Bush Hog 296 6ft...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
