Rotary Cutter Bush hog
/ Bush hog #1
Gizmo36
Platinum Member
East of Duewest S.C.
The bottom seal is leaking on my Howse 5 ft bush hog .so I am going to put the Front seal and the bottom seal in. When to Howse web site to get two seals and two Gaskets Front and bottom but can not make heads or tails of what to get .if any one has time to look I would appreciate it. model 500 Thank you.
300, 350,400, 500
/ Bush hog #2
Here's what I come up with.
45hp gearbox
Gearbox section
E9 45 -351 input seal $4.39
E10 45 -350 output seal $4.39
/ Bush hog #4
Short of doing all that work you could just pump the gearbox full of grease gun grease. A seal that won't hold oil will often hold grease. I've got an old Hyco that's run on grease for years.
/ Bush hog #5
Charles, I've run my model 500 with grease in it since 1992, the year I bought it. Like you I was going to replace the seal and the dealer I purchased it from recomended I just pump it full of grease. Too many nasty things get hung up around the shaft.
/ Bush hog
I have two seals on the way . But I may fill it with grease when I put the new seals in . If that will work just as good.
/ Bush hog #7
If you drop in new seals, and you want to go back with grease, then either:
Use JD cornhead grease
or
a 0# 'pourable' grease.. ( rhino, for instance has a pourable lube available )
or
Go back with tube grease, and then add 5oz of 140w gear oil.. it will make it soupy and sticky.. but shouldn't leak.. but will help the grease slump back down into the gears instead ov making a hollow cavity.
Soundguy
/ Bush hog
It making a hollow cavity and getting no grease on the gears bother me.If 5oz of 140 gear oil will fix that it sounds good.
/ Bush hog #9
You may have to expirement with oil oz vs the type of tube grease you use. some greases are stiffer than others.
Should be easy to check with a small wire.. or rod. Just add grease and some oil.. start with only a little bit of oil.. add more as needed.
Soundguy
/ Bush hog #10
Just a little running will get the grease "flowing". It would have to be pretty cold to lose lubricity due to "cavitating". Thats not been an issue that I've ever encountered.
/ Bush hog #11
I've rebuilt a few boxes that I opened up that had a slug of grease slung out on the walls.. and the chewed up gears running in a hollow cavity...
Keep in mind that not all gear boxes generate the heat needed to liquify grease.
That's why a few oz of gear oil will get it nice and sticky.. that or just use a 0# grease anyway.. like a cornhead grease..e tc.
Soundguy
/ Bush hog #12
Bonehead question, but what if you literally pack it with grease? In other words, fill it up, run it, fill it some more, etc until there is no room for cavitation. Would that much grease start to cause a problem?
/ Bush hog #13
if its truely that full of grease i think you risk blowing a seal when it heats up....
/ Bush hog
I think I am going to use the cornhead grease .I have not made up my mind yet.Still looking at it all till my seals come in. The cornhead grease dose it need 140 oil mixed with it.or is it lose enough to stay in the gears.
/ Bush hog #15
its my understanding that "cornhead" grease IS #0 grease (or the wird spooge of thick but thin grease already)
so no it doesnt have to be mixed with 140
/ Bush hog #16
Cornhead can be used straight.. it's actually made for gearboxes.. and is a pourable grease.
As the other poster said.. packing a gearbox plum full of grease ( or oil ) will probably cause seal failure...
Soundguy
/ Bush hog #17
I had the same problem with my auction bought Woods MD172 (bad lower seal). After much quandary and research, I said screw it and fixed it the right way by replacing the seal (which cost $5). The local Woods guy said that if you just use grease often the front bearings will crap out due to a lack of lubrication.
/ Bush hog #18
That's why you have to use a pourable grease.. so that it doesn't form a cavity around the moving parts. If no 0# grease is available.. then straight tube grease and a few oz of gear oil work great...
Soundguy
/ Bush hog #19
Sound Guy is right about the grease and a few ounces of oil. They do make #o and #oo grease that is real fluid just for gear box use.
J.M.H.
John Deere Quick Hitch (A64127)
John Deere Quick...
Cute Electric Car (A62679)
Cute Electric Car...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
New 43X16-20 NHS tire on 6-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 43X16-20 NHS...
2018 John Deere 3033R (A64126)
2018 John Deere...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
