Bush hog gouging
/ Bush hog gouging #21
Many of these posts are alluding to changing the height of the Top Link. Try not using the Top Link and running with the tail wheel up an inch and controlling the height of cut with the 3 point lift. Of course make sure the lift pins are tight and without slop. Can be putting down pressure on turns if the link is tight and the outside is slightly uphill.
/ Bush hog gouging #22
Adjust your top link and lift so that the front of the mower is higher than the rear and your tail wheel should be in contact with the ground. This should minimize gouging when turning but not eliminate it especially with a single tail wheel and uneven ground.
2022 EZ-GO ELITE...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
