Rotary Cutter Bush Hog Gear Box Leaking
/ Bush Hog Gear Box Leaking #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I am leaking gear oil out of the gear box of my cutter. Has anyone changed the seal on one of these gear boxes? Is it a very difficult job? Thank you for your input.
/ Bush Hog Gear Box Leaking #2
Front seal or bottom? Front is an hour job, tops. Piece of cake. Bottom isn't cake.
First you'd need to remove the stump jumper. Could be a hard job, OR, it could be a horrendous job. Not fun at best. That exposes the seal... re-install everything.
Alternative... Run heavy grease in place of gear oil. It's done all the time. If the seal leaks out the grease, you're no worse off. If it DOESN'T leak, start mowing.
/ Bush Hog Gear Box Leaking #3
The bottom seal on my 3 year old IM602 started leaking last summer, but not from actual use. I'd put it away after mowing - and the deck was dry. Come back the next time I needed it, dirty gear oil fouling the deck.
Finally dawned on me that the hot Kentucky sun in July/August was heating up the inside of the transmission case. Because the fill plug was unvented, the expanding contents had to go somewhere. The oil level wasn't high enough to push out the top seal, so it came out the bottom.
Solution; a three dollar vented fill plug. But if you come back and say you've already got a vented fill plug.....then brace yourself for a seal change.
//greg//
/ Bush Hog Gear Box Leaking #4
Greg G reminded me when the Bush Hog SQ480 I had started leaking oil. Bush Hog brands have vent plugs in the top. If you take it out and hit it in the palm of your hand you should feel the relief spring vibrate, if not then you need to clean it. I soaked mine in mineral spirits for about 30 min. and that freed it up. If the leak is from overpressurizing of the gearbox then you will be in good shape if the seal itself has not been damaged. Good Luck!
/ Bush Hog Gear Box Leaking #5
Come to think of it, you're right - mine rattles when I shake it. Guess that means it's never gotten plugged up on me yet. I'll stick that in my memory banks for future reference. Thanks
//greg//
/ Bush Hog Gear Box Leaking #6
I'd try changing the gear oil first. You can probably suck or syphon it out through the vent hole if you remove the vent. Then put new in. If it isn't leaking very much, this often stops it from leaking for quite a while.
Ralph
Heavy gear grease? Exactly what type of grease are your referring to? Regular old grease that I put in zerk fittings or something more specialized?
/ Bush Hog Gear Box Leaking #8
Yup. Plain old grease gun grease. You could spend a little mor and get a bettter grade, but "farmer's grease", the cheap stuff you use for the disc bearings, will do. If you want to go the extra mile, go to the local JD dealer and get a few tubes of Corn head grease. This is a little thinner, yet still a solid, but will flow in the bearings a bit better. You will need 2-3 tubes depending on the size of the gear box. Those tubes don't hold as much as you would think. Mike
/ Bush Hog Gear Box Leaking #9
I have a very old FMC brand bushhog that had a leaking lower seal. For a couple years I just topped off the oil before I used it. When I finally decided to change the seal I was completely unaware of the adventure I was embarking on. This cutter is in my estimate about 40 years old. The blades are attached to a solid bar instead of stump jumper. Anyway, it required a high quality puller, a 3/4" impact driver, a torch, and a drift pin from the top side of the cutter driven with a 16# sledge. Once the blade bar was off the shaft I could easily remove the gear box. I then had to disassemble the gear box to get the shaft out followed by the shaft seal. The old seal had to be visually matched as the part number could not be cross referenced. I learned a lot, but I still question whether it was worth all the trouble verses topping it off occasionally.
/ Bush Hog Gear Box Leaking #10
I had one that I tried to change, ended up selling the durn thing for scrap when the gearbox when south on me. I couldn't get the stumpjumper off, so I kept filling it with 90wt before using it. Guess the leak got worse or I used it just a hair too long.
Changing the lower seal can be a job! I built a gear puller just for bush hogs and sometimes it wouldn't work and it was over built to say the least.
David from jax
/ Bush Hog Gear Box Leaking #11
I had to change the seals in mine right after I bought it. and OH Heck it was hard ,finally had to go to the dealer and ask how to get it apart ,it is a Bush Hog 105, tapered shaft. dealer service guy told me to loosen nut a few turn but leave nut on to protect the threads then set deck over something solid so nut is resting on solid (a couple cap blocks) ,then go through top hole for blade removal . place something solid (old sledge hammer head no handle) on blade bar, and smack her a few good licks with a sledge hammer..//came right off on the 6th hit ,, seals where cheap everything is great now..little cedar trees dont like me now :)
/ Bush Hog Gear Box Leaking #12
Snapper makes some 00 grease (Zero-Zero) that works good for me. Mine is a Bush Hog 48" cut.
/ Bush Hog Gear Box Leaking #13
Regardless of which seal is leaking, the critical part here is how much (if any) lateral movement is there in the shaft that seal rides on. If you can feel it move side to side when force is applied, you're looking at more problems down the road if you don't address that. Adding grease to thicken the pudding won't hurt anything, been done many many times. Point is, if you have bearings and shafts running loose, then grease is only a band aid. It won't solve your problem, merely prolong what's coming.
/ Bush Hog Gear Box Leaking #14
I replaced the bottom seal on one a few years ago. I am NOT a great mechanic. I was prepared for an ordeal but the thing came apart easily, the new seal went in like a breeze , and it hasn't lost a drop since. Think I was lucky.
/ Bush Hog Gear Box Leaking #15
15 year old thread;)
/ Bush Hog Gear Box Leaking #17
Establish that you have a case vent and that it is open.
Could be a piece of string in in. Reach up there and see.
If you run grease, mix the grease with gear oil. Actually put both in a container and stir the two together to mix them. If you just pump grease in the box, it will never mix. Ive had gearboxes you couldn't keep lube in. Mixed oil into grease, it stayed fine then.
/ Bush Hog Gear Box Leaking #18
Experience with JD 127 Gyramor: #2 grease + gear oil leaked out; #1 or 0 grease stayed in. No problem for years of hard use adding an ounce or so each year.
/ Bush Hog Gear Box Leaking #19
I've had two that I ran straight grease in, as it warms up it gets everyplace and has no problem at all keeping everything lubed.
I never lost a bearing or had any problems from doing this.
SR
/ Bush Hog Gear Box Leaking #20
SR
I find that #2 is ok when the bushog is used in shock producing situations often. Too much smooth running is not optimum as the grease stays pushed away from gears and bearings. I like #1 or 0 which almost flows. TSC economy grease is ~ #1.5 -- its seems to work well. Convenient.
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2007 GENIE Z60/34 TELESCOPIC BOOM LIFT (A60429)
2007 GENIE Z60/34...
2025 JMR Tree Boom Mini Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
NEW HOLLAND TC55DA TRACTOR (A60430)
NEW HOLLAND TC55DA...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
