Bush Hog Chain Length
/ Bush Hog Chain Length #22
Any reason why someone couldn't add two chains to an American style bushhog? Two blades, plus two chains, each 90 degrees off from each other.
Good, bad, ugly?
/ Bush Hog Chain Length #23
Good, bad, ugly?
Both might be a bit too much for the tractor. I would use either two chains or two blades but not both. You guess already use what we would consider "over sized mowers" for your tractors, chains do eat a lot more HP, very noticeable difference.
I'm a little concerned on how the gearbox will handle it, as I've seen several threads with broken spindles. It will probably handle just fine and yes, it would be very easy to add two chains. We use grade 80 chains. 3/8" chains for mowers up to 3.5 ft, 1/2" chain for 4 ft up to 6 ft, and the bigger boys will use 3/4" and bigger.
/ Bush Hog Chain Length #24
Makes sense, thanks!
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
JOHN DEERE R4023 SELF-PROPELLED SPRAYER (A64277)
JOHN DEERE R4023...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
