Bush Hog Chain Length
/ Bush Hog Chain Length #22
Any reason why someone couldn't add two chains to an American style bushhog? Two blades, plus two chains, each 90 degrees off from each other.
Good, bad, ugly?
/ Bush Hog Chain Length #23
Good, bad, ugly?
Both might be a bit too much for the tractor. I would use either two chains or two blades but not both. You guess already use what we would consider "over sized mowers" for your tractors, chains do eat a lot more HP, very noticeable difference.
I'm a little concerned on how the gearbox will handle it, as I've seen several threads with broken spindles. It will probably handle just fine and yes, it would be very easy to add two chains. We use grade 80 chains. 3/8" chains for mowers up to 3.5 ft, 1/2" chain for 4 ft up to 6 ft, and the bigger boys will use 3/4" and bigger.
/ Bush Hog Chain Length #24
Makes sense, thanks!
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
INSPECTION (A61166)
INSPECTION (A61166)
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
