Bush Hog BH25?
/ Bush Hog BH25? #1
rodm1
USA
Ford
I'm in need of a new cutter and looking at a BH25 in the last few years has any problems come up with them how are they holding up? Are the new models still shipping with a chinese gear box and how are they holding up? I see in the past you could get two different gear boxes is that still the case?
Thanks!
/ Bush Hog BH25? #2
All manufacturers use Chinese gear boxes now to my knowledge. Didn't know you could get option on the gear box on the Bush Hog units. Bush Hog is a great brand with excellent dealer support. I bought a used Brown last year that I am happy with. Little dealer support but parts can be ordered from the factory. The 25 is a good heavy unit that should give you years of service. Woods, Land Pride, Deere, and Rhino are others that make quality units.
/ Bush Hog BH25?
I think that whose during the transition period from the 200 series to the BH models but not shire. My dealer didn't give me an option when I whose there. Any idea how hard it's to hook up to a standard cat 1 hitch there seems to be a sleeve setup over the life pins and I can imagine it's going to be a pain to hook up to? Unless to sleeves are for the quick hitch only.
/ Bush Hog BH25? #4
Those units are designed for both cat 1 and 2. The pin will accommodate either hitch ball. Hook up has never been an issue with my Brown cutter. You use the pin that matches your hitch ball.
/ Bush Hog BH25?
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
