Bump up lift capacity of L3400/LA463 Loader
   / Bump up lift capacity of L3400/LA463 Loader #231
Where are you guys buying your female quick coupler for LA463 loader?
   / Bump up lift capacity of L3400/LA463 Loader #234
No problem, I did see you have a B2910 so it might not work for the L xx00 models but always good to see photos :D
teg,
Here ya go - taken from the operator's seat:
(Cover for the valve is off because I'm in the process of adding front aux hydraulics for a grapple)
   / Bump up lift capacity of L3400/LA463 Loader #235
teg = you bet, and think I can tighten it a bit more!
I bet you can if not done right the first time.
That is absolutely the wrong way to adjust the pressure on that type relief valve.
You should insert the correct shims and torque the hex plug to the specified ft lbs and then don't mess with it.
   / Bump up lift capacity of L3400/LA463 Loader #236
I would have to imagine there are a certain number of L series out there that have a hex bolt improperly torqued, thus reducing loader performance. IMO it is worth checking the possibility before committing to adding/ swapping washers .02
   / Bump up lift capacity of L3400/LA463 Loader #238
teg, Here ya go - taken from the operator's seat:
Thanks, yea, you got extra room... mine's a bit tight (especially after installing my extra spool).
J_J, I guess I'll tighten her down and see what she reads... Dealers are not going to "play with shims" to get it right. I'm guessing most of them do the final adjusting with tightening it up until it reads a target psi. I assume none of them torque to a certain number.
   / Bump up lift capacity of L3400/LA463 Loader #240
LOL ... yeah, I'd say so ...
Still ...
C'mon ... post a shot of the left side of that valve set up ... I'll bet it could be shoehorned in there somewhere ... :D
403 (A52706)
403 (A52706)
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
CASE IH 183 - 8R FOLDING CULTIVATOR (A52708)
CASE IH 183 - 8R...
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
1969 VOLKSWAGEN BUG (A58018)
1969 VOLKSWAGEN...
