Bukect level idea
   / Bukect level idea #1
J0be269
Carrollton, Georgia
Kubota B2620
I know many have made different FEL bucket level indicators, many very simple and cheap. One flaw I regularly see is if it is large enough to be easily seen from the operator's station, it is subject to being torn off. With the help of my electrical junk drawer I've devised an idea. Please poke holes in it any way you can.
I have a small inductive prox switch (closes a contact when a metallic object is in front of its sensor, not touching it...just near it). I also have a large green 12v led with bezel and all that good stuff. So here is my idea.
Find a nice, out of the way mounting location, where I can effectivly guard the switch from damage with a steel guard. Mount switch and level bucket. Install a metal "flag" for the prox to "see" on a moving componet of the FEL bucket. Now with the LED mounted on the dash of the tractor, any time the bucket is in the level position and the machine running you get a nice green light.
I know this is a little over complicated for the task but it also doesn't require me to lean over to see the bucket lip. I work in a technical/electronic field and this would be an extremly easy project to do and repair when needed.
Another thing you could do with this setup would be more expensive, but also handy. Ever seen a toyota forklift that has the fork levler on it? hold a button in and lover forks, they stop on level. You could use this setup and replace the light with a relay and solenoid operated hydraulic valve to stop the motion when you reach level.
For now I'm just thinking on the indicator light setup though. So please, poke away at my thoughts and tell me any problems you see with it.
   / Bukect level idea #2
The bucket level thing that is on most tractors is only in the same plane as tractor.
I was trying to come up with one to help flatten level off camber stuff
I was thing of some sort of pendulm thingy that as hanging down with a n/c prox switch to sense a point so would level the ground.
tommu
   / Bukect level idea #3
You could just take the mercury switch out of an old round style wall thermostat. Use two of them kinda back to back, no lights means level, top light means dump a little more, bottom light means curl a little more.
This would be "level" wrt to the earth (the earth's gravity).
   / Bukect level idea #5
Good idea, How about instead of one prox. sw. use three and three LEDs. Have the center prox. as the target (say green LED). Then a prox. on each side (yellow or red LED) this would let you know when you are getting close to level (target prox. sw./green LED). If you are going to run two wires up the boom and to the operators pannel might as well run 4.
   / Bukect level idea #6
nice Idea I might try a couple things instead of the prox switch for anyone that does not have one handy.
I would use a magnetic switch and then you just have to cement a magnet across from the switch when the bucket is at a level position.
an industrial type microswitch with something welded in place to activate the switch when the bucket is level.
You basic idea sounds great though.
   / Bukect level idea #7
You need to bench test switch. It probably will not have the same make/break in both directions. This usually due to magnet not being centered in the housing. Also magnet may need to be closer to make switch and can move farther away before break. Mag can be removed from housing to solve one problem but you will need nonmetalic spacer between mounting surface and magnet. Big glob of silicon works.
   / Bukect level idea #8
Considered a water level? Clear "U-shaped" tubing w. colored liquid and a mark on each upright end.
   / Bukect level idea #9
Sounds complicated to me but VERY interesting. I look forward to seeing where it goes.
The level indicators are one of those funny things that don't seem to be all that important. but not have one I sure miss it. Mine got ripped off and bent up, but I soon straightened it and fixed it.
Funny how some seemingly simple devices are missed.
Keep us updated,I always like new and creative things.
Al
   / Bukect level idea #10
I pulled a device off an old adjustable conveyor a few years back that might be of interest to you...
It was a single axis, multi position mercury tilt switch. It was smashed but I took it apart anyway just out of curiosity (as you do). Heres a simple sketch of how it worked...
The "common" was the 'power in' side of the device and each "output" had a seperate wire running back to a controller. There was a mercury ball that would make contact between the common side and output side of the device and depending on the angle and position of the mercury ball, it would give a different output..
This switch must have been 10-15 years old.
Its totally the same principle as a cheapo sailboat tilt meter but adapted for electronics.
If I had a FEL, I think I would stick to the simple rod position indicator...
2007 Ford Edge SEL SUV (A50324)
2007 Ford Edge SEL...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
John Deere 7430 (A50120)
John Deere 7430...
PT Canal Pump (A50121)
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A50323)
2012 Peterbilt 382...
