Built two decks this weekend
/ Built two decks this weekend #21
I see the rear deck does not have stairs to the ground. Did your old deck and if not,why not?
Nice job though. I'm the same way, once I start something I like to finish it ASAP.
Old deck didnt have stairs either.
There are already three ways in/out of the house....front door, in thru the garage, or basement. Dont need/want a 4th entry point to track in directly to the dining room.
/ Built two decks this weekend #23
And that I dont understand. Perhaps if hanging a ledger, and support beam away from the house, the logical direction for joists to run is perpendicular...thus making deck boards horizontal?
Wrap around porches, will have boards on one side being horizontal, and perpendicular on the other...unless you go on a 45 degree.
Yeah, a lot of the old porches did 45 or cross hatched 45 at the corners. A neat way to do it is put a board down the 45 and butt up on each side of that, instead of having all the boards butted directly together.
I think the typical tendency with decks is to have a ledger on the house and then a beam supported by posts away from the house, so the joists run perpendicular. Almost all the decks I see are built this way. But the two porches we put on our new house are framed just like your decks.
/ Built two decks this weekend #24
Thanks for the compliments.
Yes, both are free standing. Just don't like a ledger board on the house.
FWIW, my father now passed on, is a world famous big building architect. He did few homes in his lifetime, but on the homes that he did do, he refused to attach a formal leger board citing that leger boards interrupted the siding and were a source of leaking and mold. Instead he buttressed the framing, and shimmed decks off of that sistered framing through the siding using lager bolts.
As I understand it from a professor of architecture I ran into, my father's method is increasing taught within architecture as the best practice.
My father also introduced the now common-place idea of spec drawing to the industry. I have no idea how anything built before 1952 is still standing.
Actually sounds like how my old decks were attached, if I am understanding you correct.
the "ledger" board was attached OUTSIDE the siding. there were thin...maybe 1/2", spacer boards in the valleys of the siding so the ledger didnt"crush" the siding. After the spacer boards were nailed on, the ledgers were lagged to the house.
Still didnt like that method. Bunch of holes in the siding where the lags go through, moisture can lay between the house and ledger, all kinds of bugs and critters build nests back in thee, etc.
I like free standing. Both work. Both work well. Just have my preferences is all.
/ Built two decks this weekend #26
Deck ledger board attached to house rim joist. Poor flashing details = water damage and rot to the house rim joist. Not much fun to repair. I like the free standing deck method.
/ Built two decks this weekend #27
I understand the reason some of you folks like free-standing, but the gain in lateral stability by attaching to the house is significant, especially on higher decks. It certainly can be done correctly. You just need someone with the right knowledge and attitude to do it right. If you are going free-standing, then you also need the knowledge and attitude to make sure it is sufficiently braced. No free lunch either way...
/ Built two decks this weekend #28
LD1, how did you attach the deck boards? Nails, screws, special fasteners? It's getting difficult to find regular treated deck boards.
/ Built two decks this weekend #30
I meant the old sized boards. Menards carries the thicker 1 1/8" boards now, so you can't make repairs with those if your deck has the 1" boards. This new treated lumber doesn't last like it used to. I replaced my deck after 5 or 6 years I think. It's been on there about 5 years again, and several boards are rotted or split.
/ Built two decks this weekend #31
Any opinions on the various types of composite decking? Lot of options now.
/ Built two decks this weekend #32
Composite last and are nicer but at 2 times the price I don't see them being worth it. The main reason is it just doesn't look real. It's better than plastic fencing but still something about natural that looks so much better.
I know some of the early composite decking wasnt real good. Heard of many unhappy people. Once the sun beat on it and it got hot, it sagged between all the joists.
I am sure the new stuff is better. But its expensive, and I dont think it looks as good. Especially with everything else....posts, joists, etc being wood also.
Properly cared for and stained, wood should last a great many years.
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2009 John Deere 1770NT Planter (A63111)
2009 John Deere...
