Built my boom pole today
   / Built my boom pole today #11
Nice looking build I am sure that will be very handy.
Could someone explain or point me to the other threads that explain in detail why that lower brace should line up under the upper truss brace ?
Its physics... If the main pole is stressed to the point of bending then the upper brace takes some of that pressure. As it the weight pulls it down, that force is going to be sent down that middle support. Since the bottom brace is not there then that force would be a direct downward force to the main beam again and the next weak point would be at the end of the bottom brace and is where it would bend. Clear as mud? If you really wanted to visualize it you could mock it up with something flexible and see where it bends as you adjust supports
   / Built my boom pole today #12
Has to do with bending moments. Where it is located now has a weakening effect on the structure.
   / Built my boom pole today #13
Lifting too much:
Thanks for the positive words and the input as well, I feel kinda dumb for not thinking of the brace positioning. The main beam is an old trailer axle and is very thick and heavy so the upper truss is mostly for looks? I intend to use it only when the hoe is on for ballast and mostly keeping the tip at or below the level of the bucket to minimize the chance of tipping. Already used it to move my hydraulic blade into the shop and am very pleased with it's usefulness.
And yes that is a Howard Rotovator with the English motor lurking in the background. Runs well, weighs a lot.
   / Built my boom pole today #16
If the beam is going to buckle at that point where the truss support post is why would adding more stress to that area from the brace below help it from failing ? The beam is trying to bend which pushes upwards and the truss is supposed to resist that force , so if that upward force is increased by having the main support post at that area wouldnt that just add more stress to the truss and cause it to fail anyway ?
Thanks everyone for trying to help I am just trying to wrap my mind around this .
   / Built my boom pole today #17
The beam is going to buckle where the brace from underneath meets the beam. This is where the opposing forces are all greatest. Putting the truss support directly above this point sandwiches that point so that the truss support above pushes down to help counter the force of the brace pushing up.
   / Built my boom pole today #18
I guess I'm a little slow. Can someone insert a diagram of the proper way to add the supports? :confused:
   / Built my boom pole today #19
Here's my proposal...
   / Built my boom pole today #20
By doing this aren't you adding more total forces to this area therefore making it the weak point ?
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
2008 Wilson Hopper Bottom Trailer (A50514)
2008 Wilson Hopper...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
