Built my boom pole today
   / Built my boom pole today
All this chatter has me rethinking my build. Perhaps I should have another brace from the bucket cutting edge to directly below the truss support. Most likely way overbuilt already but overkill is how I wobble...
   / Built my boom pole today #62
You would only gain more strength because you shortened the length of the boom cantilever.
The boom has to be treated as a seperate member and regardless of where the lower leg support is placed in relationship to the truss support the failure will be at the lower leg support.
Unless someone can prove otherwise the placement of the truss support directly over the lower leg would only get you a very very slight increase in strength if any at all.
   / Built my boom pole today #63
Yours looks fine, you could put a plate gusset in there if you are worried.
That's what I did to extend the support, But I don't even have the truss and have had no problems.
Why did you choose to put the receiver in the bucket?
JB.
The receiver is used to move any one of the 6 trailers I have. Top of the bucket was too high, nard the tail of some trailers drag.
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
(2) UNUSED FUTURE 10' SLIP-ON FORK EXTENSIONS (A60432)
(2) UNUSED FUTURE...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
