Building Quick Attach Plates
/ Building Quick Attach Plates #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I called PT and found out a quick attach plate for my PT is $200 apiece and then shipping.
So I went to my machine shop and for well under $150 I have all the steel cut, bent and ready to weld, and that is for 6 of them.
Will start the welding tomorrow.
/ Building Quick Attach Plates #2
That's awesome. Wish I knew how to weld
/ Building Quick Attach Plates #4
Please take this comment as it is intended (kindly). Stop wishing and get a welder and start learning. You can do it.:) Good luck on your welding journey!
/ Building Quick Attach Plates #6
Very nice!
/ Building Quick Attach Plates #7
Nice, look forward to the after pics. What's your delivered price to No. VA.? :D
What did you use to notch the plate? Cuts look very uniform and clean.
/ Building Quick Attach Plates #8
I agree. A small, name-brand 120v wire feed/MIG welder can be had for a few hundred bucks.
You can start with flux core wire or convert to MIG later if you want.
Take a class at a local community college, or get someone with welding skill to teach you basic procedures.
It isn't hard at all.
Now, I won't get into the 120v vs 240v wars here. This isn't the forum for that. There's plenty of flames (get it, flames) in the welding forum. haahaha
But if you think about it, if you spent $400 bucks on a welder, helmet, gloves, welding wire and some practice metal, then weld up just one or two useful items, you've paid for the welder and accessories!
DO IT!!!!
:blacksmith:
I bought a 200 AMP Stick from Mike at Everlast and it is killer. The price was much better than a used Lincoln tombstone (which I love and have) and the arc and weld are so much better.
I think if you are to have one welder, IMO the stick is the better way to go as you probably will do more thick than thin metal if you live on a farm.
/ Building Quick Attach Plates #10
Not to derail, but what are quick attach plates?
Thanks,
/ Building Quick Attach Plates #11
Thanks,
The plates he is building are for the Powertrac tractors they own. They are similar to the SSQA standard quick attach for Front end loaders and grapples and forks and such, only propriatary to the Powertrac. The plates will probably be used to put on to other implements they would build or buy to adapt them to their system. This is all conjecture of course as I don't have a Powertrac tractor, but that is what I think until proven wrong (and I have been before:))
/ Building Quick Attach Plates #12
You got it right....
The quick attach on Power Tracs is standard on all models (weren't a long time ago). All implements mount on the FEL arms on the front of the tractor. There is a male plate permanently attached to the FEL and all attachments have female plates, which is what Woodlandfarms is building. You can change an un-powered implement in 15 seconds without getting off the tractor. Powered implements (all powered implements are powered by hydraulics) take a few seconds longer because you have to get off the tractor and hook up the hydraulic hoses. So figure 45 seconds if you don't stop to admire the tractor. :laughing:
/ Building Quick Attach Plates #19
But man, that's a good lookin' machine (it's right there, behind the guy in the stupid hat).
