Building Quick Attach Plates
   / Building Quick Attach Plates #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I called PT and found out a quick attach plate for my PT is $200 apiece and then shipping.
So I went to my machine shop and for well under $150 I have all the steel cut, bent and ready to weld, and that is for 6 of them.
Will start the welding tomorrow.
   / Building Quick Attach Plates #2
That's awesome. Wish I knew how to weld
   / Building Quick Attach Plates #4
Please take this comment as it is intended (kindly). Stop wishing and get a welder and start learning. You can do it.:) Good luck on your welding journey!
   / Building Quick Attach Plates #6
Very nice!
   / Building Quick Attach Plates #7
Nice, look forward to the after pics. What's your delivered price to No. VA.? :D
What did you use to notch the plate? Cuts look very uniform and clean.
   / Building Quick Attach Plates #8
I agree. A small, name-brand 120v wire feed/MIG welder can be had for a few hundred bucks.
You can start with flux core wire or convert to MIG later if you want.
Take a class at a local community college, or get someone with welding skill to teach you basic procedures.
It isn't hard at all.
Now, I won't get into the 120v vs 240v wars here. This isn't the forum for that. There's plenty of flames (get it, flames) in the welding forum. haahaha
But if you think about it, if you spent $400 bucks on a welder, helmet, gloves, welding wire and some practice metal, then weld up just one or two useful items, you've paid for the welder and accessories!
DO IT!!!!
:blacksmith:
I bought a 200 AMP Stick from Mike at Everlast and it is killer. The price was much better than a used Lincoln tombstone (which I love and have) and the arc and weld are so much better.
I think if you are to have one welder, IMO the stick is the better way to go as you probably will do more thick than thin metal if you live on a farm.
   / Building Quick Attach Plates #10
Not to derail, but what are quick attach plates?
Thanks,
gps trailers (A56859)
Freightliner Fuel Truck (A56438)
Freightliner Fuel...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2013 Jeep Wrangler 4x4 SUV (A59231)
2013 Jeep Wrangler...
2010 Case 580N (A60462)
2010 Case 580N...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
