Building my tractor bridge across the creek
   / Building my tractor bridge across the creek #61
Very well thought out and erected. There are many ways to do this, you did good! I would bury the telephone pole cut offs upstream ahead of each bridge abutment.
   / Building my tractor bridge across the creek #62
Very well thought out and erected. There are many ways to do this, you did good! I would bury the telephone pole cut offs upstream ahead of each bridge abutment. You would have to get a Permit (never happens) from our out of control Conservation Authority in my area to do that.
Thanks, grumpycat and Gord. It was a fun project and is holding up well so far.
   / Building my tractor bridge across the creek #64
In Canada!
EVERYTHING....... must be permitted!
   / Building my tractor bridge across the creek #65
   / Building my tractor bridge across the creek #66
Very handsome bridge.
Based on my experience, despite the fact that the 'phone pole are fresh and well treated, in 15 or 20 years you will wish that you had obtained some aluminum flashing to cover the poles, individually, beneath the deck.
Even double heavy roofing felt will deteriorate. Over 20 years.
I used some good countersunk heavy-Zn lag bolts, (on the deck) so with a little ambition, I could follow my own advice, but I figger they'll last "as is" the short while longer that I'll be giving a damn. (77, but who is counting??)
:sleep:
Yeah you may be right about that Darvish. I suppose my bridge will last a good long time, but at some point I will probably lose confidence to drive my tractor across it. Hopefully the fasteners don't rot too quickly, and then it will be straightforward to disassemble and rebuild - assuming my footers/abutments hold up.
Had a major flood test last friday night. Just posted another thread about having to repair my gravel driveway, which has never washed out from rainfall before (6+ years now). I think we got between 5 and 6 inches of rain, with most coming in a very intense 3 hour period.
The next morning before starting on my driveway repair, the kids and I took a hike back to inspect the creek. I knew I would need to wear my waders. Came over the hill and this is how the trails looked in the forest:
Looking at the mud-stained leaves of the weeds and bushes on the trail sides, I could see that the water had already come down about a foot! But the bridge survived, thank goodness.
If you look closely you can see foam remnants on the bottom side of the phone pole - they were clearly getting washed hard with flood water. The front/upstream cinder block got washed pretty hard also. I think I will need to place some armoring in front of it for future protection.
My little temporary footbridge didn't fare as well, and it blew down the stream a bit. Time to yank it out already.
This was the most intense rain, and highest creek flooding I have ever seen on this piece of land, in over 8 years of observation now. I'm feeling truly relieved and grateful that nothing really got damaged. Mother nature is a powerful force.
   / Building my tractor bridge across the creek #68
Glad your main bridge survived, you put a lot of work into that.
New visitor for my bridge. The troll approved our crossing, thankfully.
   / Building my tractor bridge across the creek #70
Congrats, if that is a new addition to the fleet Mr. Deezler.
TANK MANIFOLD (A55745)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HUSQVARNA RIDING...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
