building boxblade
/ building boxblade #1
tractorwheel
I am going to make a homemade boxblade. Has anyone made one and what are your suggestions. Also, if you made one and then after using it decided you should have done something different. All comments are appreciated.
Here is a photo of the tractor it will be used on
/ building boxblade #2
I made this outta some sheet steel I found along side of the road.
One of these days,I'm gonna cut loose the brackets holding the "wings" on and make them pivot to the rear so I can use it as a straight blade too.
/ building boxblade #4
Haven't made one yet but want to also. You can get box blade shanks at a reasonable cost shipped from Agri-supply.(they have a few different styles) I've seen plans for one somewhere also. Agri-supply
I plan on making mine 4' with 4 rippers and some scrap steel I have.
/ building boxblade #5
</font><font color="blue" class="small">( Haven't made one yet but want to also. You can get box blade shanks at a reasonable cost shipped from Agri-supply.(they have a few different styles) I've seen plans for one somewhere also. Agri-supply
I plan on making mine 4' with 4 rippers and some scrap steel I have. )</font>
Mark,
Our local TSC has those same shanks/scarifiers for about $12.00 each. Shipping on thsoie would cost almsot as much as the shanks themselves.
Gotta be frugal here. The more money you save on one project, the more money you have to use on your next project. Remember, always think ahead /forums/images/graemlins/grin.gif
/ building boxblade #6
Surprisingly, Agrisupply doesn't charge shipping by weight, they charge by $ amount of order. (At least my last shippment was still that way in Oct.). So I order as much heavy stuff from them as possible in the same order. Unfortunately no TSC around these parts.
/ building boxblade #7
Great tip. I am new here to the TNC and looking for these kind of tips.
I have already requested a catalog from Agrisupply...probably stop by the Tifton retail store on my way to my NC property.
Thanks.
/ building boxblade #8
I built one out of 10" I-beams I had laying around, with a piece of 4x4 square across the front/top which I welded 3x3x3/8" angle iron as uprights for the top link. Didn't have any problems with the build, just a little welding.
The bottom flange of the I-beam is sometimes a problem but it is great for some projects so I leave it on.
David from jax
30x57 Welding Table (A65640)
30x57 Welding...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
213121 (A64276)
213121 (A64276)
Hedge Posts (A65640)
Two (2) John Deere 4000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
