Building A small pull pan Type scraper
/ Building A small pull pan Type scraper #11
Thanks!
Kinda what I expected to see.
Basically we see these (bigger) behind big bulldozers and often pushed as well.
While a cool idea, I can not see my 20 HP pulling this in my type of soil conditions as the cutting edge would bounce off of each and every 6"rock in its path.
Heck, even my FEL (48" wide) deflects off of a 4" stone without the tooth bar.
But great for loam and sandy soils, I'd think.
Ron I seen those before and I think that maybe the only small machine avaible the 4 ft cut sells for more than $6000. USD.
Also the lack of a front closing gate is a BIG problem as a lot of the dry soil will sluff out during transport and worse if the groung you are driving on is rough. It also will not move dry gravel. Now I have never used that model, but I have that problem if my front doesnt close. I had a lot of problem with both mine when I just got them out of stoarge as they had rust but after much use they work great. No front gate big problems.
It may have been somthing like it but these have never before posted on the web and I only took these pictures a few hours ago they are as they set at my farm this very minute. But like I said for years both of these model were built commercialy for years but no longer.
/ Building A small pull pan Type scraper #13
The scraper is the best kept secret in earthmoving. Now, it's not really a "secret", but it's use is something that has waned for the small operator.
Years ago, the "Fresno" as it's called (essentially the 2-wheeled unit pictured above w/o the wheels) was king behind animal or tractor power. I still have one and find it useful in some situations. The use of small dirt-pans for CUTs is rare. A dirt-pan is a fantastic tool and a dirt tank (or "pond") can be built with one of these by the small owner in decent time and much fun versus a dozer. The combination of dirt-mowing and compaction versus size is impressive. You don't see anything less that 3 yd capacity today, and that's rare.
PILOON:
These scrapers have gone through some of the most rocky and stony ground soil that Neb, Wyo and WA had to offer. Now my farm has rocks but not as much that these have been through.
I have loaded rock as big 14 inch 50 lbs each with the soil with either of these machines. Last winter when it was sunny I cut soil that was frozen soild. They seem to either roll rocks in or pass over it and catch the rock when it is exposed enough. Both these machines had set for the last 35 years unused at my brothers place. It wasnt untill I got this farm and needed to have such machine that I brought them from stoarge. Now I seen my Dad use them but I was just a little kid then. We only kept them because they were Dads machines. And we all heard the story of them many times. I just recently descovered the construction notes of them in Dads old papers. I have both a 8 ft 4 way back blade and box scraper both of which I quickly found out the limitations of both. It is when a guy needs to move dirt more than a couple hundred feet or move dirt across a road or field that these machines shine. Also the amount of dirt that can be moved. Last summer I moved more than 1200 yds in just a few days. This year I will finish the job with about 2500 yds left to do. Then this farm will be ready to irragate. I also built the road grades needed here.
/ Building A small pull pan Type scraper #15
those things are pretty cool.
a front end loader on a small tractor is 1/2 yard bucket. If we can really get 2 yards, then that is 4 times as fast. Also, because you are spanning, it would be a LOT easier to make things flat.
if we are doing 2 yards, that is like 5000 pounds of dirt. there would be some leverages involved so the thing would really dump given hydraulics.
/ Building A small pull pan Type scraper #16
I would love to have something like that, need it actually, but can't spend the 6k+ they want for a small scraper. I ended up buying a small 4000# dump trailer that will hold 2 yards. Between that and the bucket thats 2.5 yards at a shot. Its a lot faster than just the bucket but takes a lot of time(to much) out the the cycle to hook/unhook the trailer for loading.
Several hundred+ yards of dirt have been moved but when you have to move a 1000 yards its to slow. I'm hiring someone to clean out one my terraces for that reason.
I cleaned out one of the other terraces but spent way to much time doing it with the FEL, BB and DT. The dirt needed to be carried several hundred+ feet each time. Other areas need the dirt carried a lot farther. Like the catch dam and check dams that have been silting up since the 60's. Bringing in big equipment would realy tear stuff up if you could get it in there to begin with.
Building one is within the realm of possibility. This has been strongly considered over the last year since I have a welder, torch, bandsaw etc.. and some skill to go with it.
Having some plans would put it over the top and be a winter project to use next year. CAD plans would be nice but not needed if the drawings are fairly detailed.
/ Building A small pull pan Type scraper #17
I love these little units and I want to upgrade both tractor and dirt-pan someday to the 3yd size. Currently, the NAA can handle the 1-1.5yd fresno though I've considered modifying it to do more.
I prefer the front dump myself for what I do with it.....empty, level, and pack at the same time. I've cleaned out a small tank with it (using a small, 5 bottom chisel to help out with loosening the soil) as well numerous dumps and road maintenance. These will pick up loose caliche gravel. Rocks are a problem, but, when aren't they? For the amount of material I can move in a single pass they are worth their weight.
The DB scraper is new to me and look very, very interesting.... /forums/images/graemlins/wink.gif
He is a scan of an early prerun Ad cut For the 2 wheel scraper
Picture of 4 wheel scraper loaded full from using today
/ Building A small pull pan Type scraper #20
I saw this used scraper for sale and it doesn't look like it is as well engineered.
Scraper 4 Sale
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
2022 TOP HAT TRAILER HYDRAULIC BUMPER PULL DUMP TRAILER (A60736)
2022 TOP HAT...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
