building a root cellar
/ building a root cellar #1
EILEEN
Desire to build a root cellar I need info on specific building needs.
/ building a root cellar #2
EILEEN, I don't know anything about building a root cellar, but be sure the door isn't built like my next door neighbor's cellar. Every time it rains, it fills up with water; about 4' deep right now and I can't get my little Homelite pump started./w3tcompact/icons/frown.gif
Do you intend to build a concrete walled and/or floored cellar, or just a plain earthen cellar. The simplest ones I've known were where they simply dug a hole with the sides as straight and vertical as possible, built some steps into one end, then laid logs across the top, covered the logs with dirt, and built a door over the steps. The neighbor's is square with concrete floor, walls, and top (storm shelter), but he erred in building the entrance.
Bird
/ building a root cellar #3
Eileen:I made one about 3yr's ago. My's concrete side's and roof, the floor is dirt with limestone, over the dirt.Check out www.root cellar.com, all sort's of nfo.
Camshaft in Pa.
2025 Rake Mini Excavator Attachment (A66734)
2025 Rake Mini...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
Lot 602 (A62613)
Lot 602 (A62613)
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2022 INTERNATIONAL LT625 DAYCAB (A67714)
2022 INTERNATIONAL...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
